| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Check a Roof for Leaks
by eHow.com
Roof leaks may not be immediately apparent, which is one of their inherent problems. As a roof leaks, there is the danger that mold and mildew will accumulate. In addition, actual structural damage is also a possibility. That's why it is so important to... Read More »
Examine Your Roof for Loose Shingles & Other Damage
by Expert Village
Hi! This is Jon on behalf of Expert Village. In this video clip, we will checking the roof for loose or missing shingles. To check for any loose or missing shingle, you just want to take a close look at your roof. If there are any areas that might look... Read More »
How to Inspect the Exterior of Your House
by Expert Village
It’s important for every home owner to familiarize themselves with the exterior of their house. A lot of times people don’t check on what’s going on outside their house. Especially on the side that they rarely see - until there’s... Read More »
Examine Your Chimney & Fireplace for Damage
by Expert Village
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be checking our chimney. Now if you have a chimney that is brick or block, you are going to want to check the mortar to make sure that none is loose or deteriorated or any missing... Read More »
How to Patch Membrane Roofing
by eHow.com
Patching a flat roof may not seem like much fun and you may be tempted to call in the experts. There are several roofing companies that only do flat roofs because of the lower amount of work involved. But you can patch your own membrane roof if you have... Read More »
