Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-10-2008, 10:53 AM   #1
Default Roof Leak Around Chimney
Hi! We bought a 14yr old house in December and the inspector pointed out missing shingles over the "ridge vent" (not sure if that's the right term...it's the vent opening at the peak of the roof) and poor flashing around the chimney.
The chimney is near the center of the roof just a few inches from the peak. The inspector said that the shingles next to the chimney came loose because the chimney is too close to the ridge vent (leaving nothing to nail the shingles too along the chimney side) and that the roofer should have discontinued the vent and made the peak solid around the chimney area.
From inside the attic I can see daylight through the section of ridge vent near the chimney and between the flashing and chimney along two sides of the chimney. During the last rain I went up and saw water coming in through the open section of ridge vent and running along the inside of the roof to the front of the house (so I guess the water damage over the front door is from this rather than from an ice dam) and running down the outside of the chimney on the two sides where I saw daylight.
This is my first home and I would like to repair this myself if possible. Is this something I could do or should I call in a professional?
I went to Home Depot this weekend and there are a lot of roofing items (roof cement, roof tar, roof fabric, flashing sealant, ridge vent shingles, etc.).
I'm thinking, use the cement and nails to attach new shingles over the open section of vent, use the flashing sealant around the flashing and then cover the whole thing with roof tar but I'm guessing since I really have no idea what I'm doing (ready, willing but woefully uninformed, that's me).
Any advice would be appreciated...regardless of whether I do this myself or hire a contractor I'm planning on waiting for some warm dry weather.
Thanks,
Robert
robertr4836 is offline   Reply With Quote
Old 03-10-2008, 10:08 PM   #2
Pro Slate Roofer
All the junk you saw at HD serves one purpose, and one purpose only. The make the manufacturer money. They do nothing to help roof leaks.
If you don't know hot to step flash, term flash and counterflash a chimney, you need a pro roofer.
Fact of the matter is, 14 year old roof, and shingles blowing off? You need another roof. 10-14 years is the life expectancy of a 20 year shingle. Sorry.
tinner666 is offline   Reply With Quote
Old 03-11-2008, 09:41 AM   #3
I work for a sheet metal shop and one of our main products is flashable curbs and rails for roof mounted HVAC equipment. My problem is that I'm an engineer, I design a lot of this stuff but I have never installed it!
The roof pitch is very steep and my fiance convinced me to bring in a pro (she doesn't want me to break my neck!).
30 year roof in excellent shape other than five or six shingles on the peak next to the chimney that were never attached properly in the first place.
Thanks for the advice RE the HD crap!
Old 03-11-2008, 01:23 PM   #4
very smart to let the roofer do the steep work.
while he is there ask him to tune the roof...look for nail pops... check flashing... if neoprene spray some armor all.. also roofers sometimes put 20 yr (thinner shingle) on for ridge cap.. have him report on overall condition.
Big Bob is offline   Reply With Quote
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip, we will checking the roof for loose or missing shingles. To check for any loose or missing shingle, you just want to take a close look at your roof. If there are any areas that might look... Read More »
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
Roofs last along time, so it's entirely possible you have owned a home without ever having to pick replacement shingles. Or, it has been such a long time there are new products on the market from which to choose. Pick replacement roof shingles by... Read More »
Hello, my name is Grady Johnson and I'm a professional painter and today I represent expertvillage.com. Okay, now we're going to talk about pressure washing a roof. Now, whenever you pressure wash a roof you want to watch out for any electrical wires... Read More »
How to Clean a Roof Gutter
How to Clean a Roof Gutter by Expert Village
Hi, this is Jon on behalf of Expert Village in this video clip we'll be cleaning and inspecting the gutters and down spouts. Now the gutters are another area that require a little extra attention. If your gutters are clogged and during the winter we get... Read More »
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing 6 03-07-2008 05:12 PM
leak in chimney water comes threw brick Kdawg Roofing 51 02-08-2008 05:18 PM
roof leak and EPDM membrane dbai Roofing 8 10-28-2007 07:16 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 08:17 AM
flat roof leak snikda9 Roofing 16 01-26-2006 06:25 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
