Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 04-23-2011, 12:35 PM   #1
Roof leak
I have a rolled roof that is on an addition that is connected to the rest of the house which is shingled. I became separated and is leaking. How do I repair it???
kk1117 is offline   Reply With Quote
Old 04-23-2011, 12:47 PM   #2
Gymschu's Avatar
Roof leak
KK, I'll say it before someone else says it.........PICS PLEASE!
Old 04-24-2011, 01:23 AM   #3
Erieparoofing.com
onarooftop's Avatar
Roof leak
That is one of the most common areas of roof leaks. Where one roof ties into another roof or roof system.
onarooftop is offline   Reply With Quote
Old 04-26-2011, 02:13 AM   #4
Roof leak
If you find evidence of shingle problems. Curled-back shingles can be attached with mineral pitch roof cement or compound in tubes for use with a caulking gun. In warm weather, you can easily straighten out the curled shingle. In cold weather, shingles become very brittle and must be softened before they can be flattened out.
myfourseasons is offline   Reply With Quote
Old 04-26-2011, 03:21 PM   #5
RFN-4A-LVN
Roofmaster417's Avatar
Roof leak
Transitions from a flat roof to a shingle roof are common problems.Pix would help.
Pitch breaks are also a common area for leaks.Pitch breaks are change from flat to the pitch of your shingled area.
Roofmaster417 is offline   Reply With Quote
Roof leak around my chimney - update GlennAble Roofing/Siding 3 11-05-2009 07:24 PM
Why Does my Flat Roof Leak? KATHIE Roofing/Siding 15 02-19-2009 12:57 PM
Help with Roof Leak ak1mking Roofing/Siding 15 11-14-2008 02:55 AM
roof leak at puncture for airconditioner neal singer Roofing/Siding 9 02-11-2008 10:52 PM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 05:25 PM
