-   -   Roof leak (http://www.diychatroom.com/f9/roof-leak-102473/)
kk1117 04-23-2011 12:35 PM
Roof leak
I have a rolled roof that is on an addition that is connected to the rest of the house which is shingled. I became separated and is leaking. How do I repair it???
Gymschu 04-23-2011 12:47 PM
KK, I'll say it before someone else says it.........PICS PLEASE!
onarooftop 04-24-2011 01:23 AM
That is one of the most common areas of roof leaks. Where one roof ties into another roof or roof system.
myfourseasons 04-26-2011 02:13 AM
If you find evidence of shingle problems. Curled-back shingles can be attached with mineral pitch roof cement or compound in tubes for use with a caulking gun. In warm weather, you can easily straighten out the curled shingle. In cold weather, shingles become very brittle and must be softened before they can be flattened out.
Roofmaster417 04-26-2011 03:21 PM
Transitions from a flat roof to a shingle roof are common problems.Pix would help.
Pitch breaks are also a common area for leaks.Pitch breaks are change from flat to the pitch of your shingled area.
