Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-30-2009, 07:26 PM   #1
roof heat tape
I have a VERY high roof and 2 years ago put top brand heat tape 120 ft, to keep ice damn clear, this year it shorted out at the thermostat by the plug, I fixed it but little wire"fuse" inside didnt stay when it got cold, any way I can cut and wire another Fuse end to the old tape? It is so hard to replace what I have and would be worth buying the tape just to replace the fuse and wiring in a new one. Suggestions???
litedoc is offline   Reply With Quote
Old 12-31-2009, 07:48 PM   #2
Dave The Roofer
Dave The Roofer's Avatar
Send a message via AIM to Dave The Roofer
roof heat tape
Try This....
Snow and ice removal systems manufactured by Thermal Technologies provide an attractive and cost effective method to ensure that a building owner never has to experience the frustration, destructiveness and cost of water damage caused by the inability of their roof to drain water during the winter months.
Dave The Roofer is offline   Reply With Quote
Old 01-02-2010, 06:22 PM   #3
Electric Radiant Heating
warmsmeallup's Avatar
roof heat tape
Something is causing the fuse to blow... twice! Look for splices in the cable that are no longer sealed. At the end, there will also be a 'termination cap'. Check it as well to be sure it is still sealed.
The fuse is made to blow when too much energy is being drawn. If it worked last year and it doesn't this, something has happened to cause it to blow. Just replacing the fuse or thermostat won't repair the problem.
warmsmeallup is offline   Reply With Quote
Blown Insulation - Flat roof AndrewF Roofing 1 12-31-2009 07:41 PM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 08:25 PM
Roof Venting Issue, crawlspace supton Roofing 1 11-12-2008 07:44 AM
