Roof Has No Soffit Vents? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-21-2011, 07:11 PM   #1
Roof has no soffit vents?
My house is 26 years old. I have been getting ice dams the past 2 years and I noticed a few days ago that I don't have any soffit vents. There are 2 roof vents and two gable vents. One of the gable vents has a fan. I noticed a lot of condensation in the attic so I covered the attic door to prevent heat loss through there. How important are soffit vents? Should I install them?
pab61 is offline   Reply With Quote
Old 01-23-2011, 03:32 PM   #2
the roofing god's Avatar
Send a message via MSN to the roofing god
down the road probably,but usually all that condensation is a result of poor attic insulation (not enough),a bathroom fan dumping moisture into the attic,or possible other issues,you can add ventilation thru fascia replacement,but will involve renovating the fascia area of the roof
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
skylights and vents in flat roof brownmoose Roofing/Siding 2 05-15-2010 02:29 PM
Soffit vents on older houses with "curved" ceilings Labman101 Roofing/Siding 2 02-07-2010 10:33 PM
Laying new roof after removal of old roof rupal Roofing/Siding 9 11-30-2009 04:00 PM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
No soffit or gable vents wooody Roofing/Siding 8 08-19-2009 08:06 AM
