Roof Flashing Cement Preference - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-22-2010, 01:14 PM   #1
Hello all,
I'm just curious on which brand roof flashing you guys prefer to use?
I currently use the Karnak brand K19 right now.
Are there any better alternatives?
I've heard of Henry, Bulldog.
cchan is offline   Reply With Quote
Old 10-23-2010, 09:39 AM   #2
RoofDiagnostics's Avatar
In areas that the temperature changes throughout the seasons drastically, flashing cement should not be considered a permanent flashing detail.
For instance, in NJ the winter/summer temp variation provides significant expansion and contraction deterioration. In these areas, whenever possible a metal (aluminum, copper) flashing is much more effective for a permanent flashing detail.
If you are insistent on using roofing cement my recommendation would be to utilize a fabrich (mesh) inlay.
Hope this helps.
By the way, as cement goes, Karnak is a reputable product.
RoofDiagnostics is offline   Reply With Quote
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Choosing flashing cement for flat roof stubits Roofing/Siding 19 08-26-2010 11:03 PM
Dormer flashing and roof trim Joe1. Roofing/Siding 10 08-17-2010 11:48 AM
flashing help needed endgrainguy Roofing/Siding 3 12-31-2009 10:09 PM
Leaking Cement Flat Roof surritab Roofing/Siding 1 01-31-2007 11:48 AM
