Roof Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-25-2010, 09:02 AM   #1
roof flashing
what is better flashing i purchased weather watch but my roofer said he prefers metal flashing.
jamiesue is offline   Reply With Quote
Old 07-25-2010, 09:38 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
those are 2 completely different things
Tom Struble is offline   Reply With Quote
Old 07-25-2010, 09:42 AM   #3
can u explain
i was quoted ice and water sheild by insurance adjuster i assumed this was for the valley.
Old 07-25-2010, 09:47 AM   #4
ok i see now,depends on how the roofer does his valley but imo you should use both
Old 07-25-2010, 09:52 AM   #5
how would u use both
Old 07-25-2010, 11:10 AM   #6
seeyou...help
Old 07-25-2010, 03:58 PM   #7
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
[quote=tomstruble;474985]seeyou...help[/quote
Can't a roofer get a day off?
I use I&WS in valleys when I re-roof regardless of whether there will be metal or not as temporary protection.
If the valley is to be shingled through (California or woven valley), I don't use metal. If there is to be an exposed metal valley, I lay it over the I&WS. I prefer to use metal, but if done correctly, the I&WS is all that's necessary in my climate and satisfies local code.
This answer may be wrong for other locales.
seeyou is offline   Reply With Quote
The Following User Says Thank You to seeyou For This Useful Post:
Tom Struble (07-25-2010)
Old 07-25-2010, 07:34 PM   #8
don't you roofers take off when its raining?
Old 07-26-2010, 12:02 PM   #9
i have another question
is it ok to leave just liner on roof overnight if there is a chance of rain
Old 07-26-2010, 12:46 PM   #10
kwikfishron's Avatar
Rewards Points: 818
If by liner you mean tarp then better to have that then nothing.
Personally I never tear off more than I can get covered up in a day.
At least new felt and if there’s a chance of rain I’ll tarp that too.
kwikfishron is online now   Reply With Quote
Old 07-26-2010, 01:15 PM   #11
ya by liner i mean the felt. the roofers told me they would only tear off what they could replace. But when i got home from work they had left and part of the roof only has felt on it. ive left messages but not had a call back yet. i wasnt sure if i should go into panic mode yet.
Old 07-26-2010, 02:04 PM   #12
Rewards Points: 818
“If” they did the felt correctly you should have no leaks if it rains.
My concern is the wind tearing the felt and raining, then you would have some issues.
I see there are some pretty decent storms brewing in your area now that may last through the night.
Old 07-26-2010, 03:35 PM   #13
so after 5 calls to my contractor and getting on the roof myself trying to cover it in plastic while it was storming no less . the contractor finally called and told me he left the old felt down and put new felt over it like a tarp. He is going to replace the felt tomorrow.
Old 07-26-2010, 04:55 PM   #14
Rewards Points: 818
[quote=jamiesue;475639]so after 5 calls to my contractor and getting on the roof myself trying to cover it in plastic while it was storming no less . the contractor finally called and told me he left the old felt down and put new felt over it like a tarp. He is going to replace the felt tomorrow.[/quote]
Thatís kind a hokey explanation.
While heís tearing off his new felt tarp make sure he tears off the old felt too and do a proper sheathing inspection before covering.
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Roof Vent Cap Flashing??? Need advice. revamped Roofing/Siding 2 07-05-2008 11:01 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
