Roof Decking Replacement - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-23-2013, 12:00 AM   #1
My existing roof sheathing/decking are wooden planks with small gaps between them. I dont think this would be a good base for the new shingles i am going to be installing. Can i install new 4x8 OSB directly over these planks or should i remove the planks and then install all new OSB sheathing, or should i just shingling over the existing plank decking?
jpm6621 is offline   Reply With Quote
Old 05-23-2013, 12:37 AM   #2
It is very common to go over perlins with osb. We do it all the time.
jsbuilders is offline   Reply With Quote
Old 05-23-2013, 08:44 PM   #3
Can i use regular 7/16 OSB to cover the deck or 1/2" plywood and should i glue whatever i use down? If im goin over the existing planks i dont want to put too much added weight on the roof.
Old 05-23-2013, 08:55 PM   #4
Rewards Points: 13,300
Just nail it down with #8 penny nails, no glue needed.
It's done all the time there is not weight issue with just 1/2 sheathing.
Plywood or OSB will work.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
av1611 (05-25-2013), Windows on Wash (05-29-2013)
Old 05-23-2013, 08:56 PM   #5
7/16 is fine. We just nail down
Old 05-29-2013, 09:13 PM   #6
Well i started installing OSB over the existing planks. Where i have two 4x8 sheets butted up together (4ft ends), i didn't end them on the rafters which i wanted to do and just nailed through the existing planks. Same thing along the 8ft sides, nailed through the planks. I was just wondering if these nails will be popping back up at all since the planks arn't in the best shape and the nails don't seam to grab the best. I used 16's and nailed those into the rafters and 8's around the perimeter. Do i need the 8's along the 8ft side or will nailing into the rafters with 16's and nails along the butt ends be fine. Since i installed some sheets allready i was going to go in the attic and put a 2x4 where the butt ends meet so theres more to nail to.
help! strange horizontal bubbles on new roof dfwnewroof Roofing/Siding 49 11-17-2012 07:46 AM
Need help deciding on flat roof replacement... BeckyFL Roofing/Siding 1 10-17-2011 11:43 AM
Decking Issue after new roof install CrankyDragon Roofing/Siding 12 07-04-2011 11:26 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
