#1 |
Roof Decking
I have two older structures joined with a roof and walls in the middle creating a third structure in the center. These outdoor, detached structures were built in the 30's and all rafters are 2' on center.
The decking is 3/4" ship lap and I understand that I need to build a cricket between the two structures to eliminate leaking problems I am having. For pics and previous post see: 1930's low pitch roof I have an abundance of this 3/4" ship lap left over from a renovation project. My existing decking has some rot and termite damage and I'd like to know if there is any harm in using the 3/4" ship lap I have. The only issue I could think of is the weight but then I wonder how it's been standing for the past 80 years without issue. My sill plates are rotted and I plan to jack the walls, replace plates and ensure the walls have a beam every 16". With the new cricket I intend to build, I will plan to space rafters every 16" on center as well. Since I have foundation issues, there may be a possibility that I will demo the structures all together in the future but for now I simply want to keep it as is. Any thoughts are appreciated. |
#2 |
Exterior Construction
Roof Decking
It worked for that long, can't see it not being effective now.
Use what you have.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Florida metal roof dilemma. | DIYorDIEtrying | Roofing/Siding | 12 | 02-12-2013 06:00 PM |
| Roof leak nightmare..... it won't stop | amandat37 | Roofing/Siding | 52 | 04-22-2011 01:47 PM |
| Replace the roof or not??? Leaked only once when it snowed | chasqui | Roofing/Siding | 10 | 04-13-2010 11:02 PM |
| Flat roof - Rolled? - leaks Advice? | JJ2001 | Roofing/Siding | 4 | 11-19-2006 07:17 AM |
| what roof decking material should i use? | chrisd11 | Carpentry | 9 | 06-18-2006 10:32 PM |
