Roof Deck - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-13-2011, 01:56 PM   #1
Question
roof deck
I origially planned on using 1x4 furring strips to support a metal roof,(weight concerns), but my wife is worried about noise from rain and dents from hail, so I' ve agreed to go with a full deck. Is 5/8" OSB suitable? I know plywood is stonger but stength is not an issue. Please send some input. I even thoght about 1/2" OSB. I"m doing every thing alone.
Robert King is offline   Reply With Quote
Old 03-13-2011, 10:33 PM   #2
roof instalation
Make sure your home will support the extra weight of the plywood and 1/2 will work, but may sag between joists if they are 24" on center. Just to be clear, you are removing the existing roof system correct? Pictures are worth a thousand words.
highcountrywnc is offline   Reply With Quote
The Following User Says Thank You to highcountrywnc For This Useful Post:
Robert King (03-14-2011)
Old 03-14-2011, 10:44 AM   #3
Arrow
Roof deck
This is a new addition,(new roof), it is 9-12" higher than the existing roof and the ridgeboard is offset 3' from the existing one. The only thing I'm tearing off is the gable overhang from the existing roof. The rafters are set 16" O/C. My question is would OSB be suitable for the decking.
RMK.
Old 03-14-2011, 04:14 PM   #4
osb use for roofing substrate
Yes, osb(1/2" or 3/4") is an approved roofing substrate(decking), remember to install rough side up. We use plywood/osb clips on the joints between the rafters to keep sagging to a minimum.
Robert King (03-15-2011)
Old 03-15-2011, 12:47 AM   #5
Roof deck
Thanks alot. Iveseen OSB deck before-just never did it. I should be decking it tommorrow. Already have clips from another job which is why I wanted to use 1/2". RMK.
Old 03-15-2011, 06:27 AM   #6
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
The type sheathing will have little, if any effect on either of these items. The noise factor will depend more on how much insulation you have in the attic and the hail dent result will be a function of the thickness of the metal vs the size of the hail. All that being said, I prefer solid sheathing over furring. Don't forget the underlayment with solid sheathing.
seeyou is offline   Reply With Quote
The Following User Says Thank You to seeyou For This Useful Post:
Old 03-15-2011, 11:07 PM   #7
roof decking
Thankyou for the reply. I'll see if I can get the wife to read this because what you say is exactly what I told her!
Deck Staining Nightmare steven994 Painting 7 06-14-2017 04:56 AM
Add roof over deck, but not before some serious DIY repairs luvdairish Roofing/Siding 1 05-30-2010 07:14 PM
Free-Standing Deck with Screened Porch Tied into existing Roof butlerbach Carpentry 2 05-14-2009 07:25 AM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 07:25 PM
Deck on Garage roof billybarty Building & Construction 2 02-26-2008 04:33 PM
