Roof Cracking, 70 Years Worth Of Roofing, Need Suggestions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-01-2010, 02:41 PM   #1
Rewards Points: 150
Roof cracking, 70 years worth of roofing, need suggestions
Hi Everyone,
I am new to the forum. Kind of retarded on my part for not realizing that something like this existed already.
To introduce myself: I'm 29. Two years ago I bought a two family house with my wife. My father-in-law and I gutted the entire second floor and built a pretty amazing apartment in the span of about two years. All done on weekends and after work. It was a biotch to say the least. I am talking about changing the layout, new plumbing and electrical, skylights, sun-tunnels, making my own doors, kitchen, bathroom, everything was hand made, hand lacquered, etc etc. I will post up pictures shortly.
I was more interested on getting in the house so I didn't bother with the roof. It seemed fine 2 years ago. I know mistake, I should have torn that **** out and taken 2 days of my life to redo it. Would have been easy to cut it out between the beams and rip everything out.
Roof type: Flat, pitch seems like 1/2" per foot, lowest point in middle of house where there is a gutter drain. Current roofing looks like rolled roof, not sure if its nailed or glued, or whatever, but it has the asphalt pebbles on top.
Well I now have a spot on my bathroom ceiling where the joint tape is coming off. There are no wet spots yet, but when I poked through the tape, it felt moist.
Got on the roof, I have air pockets , punctured a hole in all of them, let the air out, patched it up with roof tar and tar-mesh (not sure if that is the proper terminology). A couple of spots were not air pockets, but water pockets . Same thing, except I used the torch to heat it up like crazy. I also have what I will describe as folds or bumps that are appearing all over the place. WTF. I am curious as to why this is happening, but either way I want to do a proper fix.
I would like to know how, and what is available to take the old roofing off. When I was putting in my skylights, I cut through the roof and the decking, and noticed what looks like 5-7 layers of roofing on top of the decking . Is this even normal? Who the hell would do something like this? I am sure this weighs a ton.
Can I get some sort of giant roofing knife, cut lines in the roof and peel it off a square at a time? Any advice would be greatly appreciated.
I am going to do a torch down roof. I have experience on putting it on top of current roofing material, but not as a new roof. What am I in for here? I am pretty sure I will need some sort of fireproof membrane. Is there something out there, and what is it called? How do I keep it in place?
Thanks for your help in advance.
slickgt1 is offline   Reply With Quote
Old 04-01-2010, 07:00 PM   #2
Commercial Roofing
AaronB's Avatar
Yes, there are roof cutters available, but if you're only doing one roof, I would suggest a cheap circular saw.
There are better options for a non-trained person than using torch down material. I strongly suggest you use something else.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-02-2010, 09:03 AM   #3
Rewards Points: 150
Thanks for the reply. Please keep them comming guys.
With the cheap circular say, do you mean that I should just cut lines in the roofing and then just peel it up?
Or are you suggesting that I cut through the roof and the decking?
More questions.
1. How far apart should I do the cuts? 2-3ft, smaller, between rafters?
2. What should I use to peel the old roofing off? I am guessing scraper, but want to know if there is some proper type of tool that will greatly speed up my process.
3. Is there a membrane that I need to put down on the decking before the torch? (I am considering other options other than torch, but I have done 3 roofs with torch, and have all the equipment for it, including fire extinguishers).
4. How do I make the membrane stay in place?
Thanks in advance.
Old 04-02-2010, 09:35 AM   #4
Rewards Points: 1,514
I would suggest being very careful not to cut the (wood) decking unless you are sure you want to replace that too (rotted?). Aside from that, any method of peeling off the layers of roofing would be okay subject to the time you have to work between rainstorms.
If there is loose gravel as in a tar & gravel roof, it would probably be less tedious to shovel the loose material off into buckets and then resume peeling off layers.
Old 04-02-2010, 10:10 AM   #5
Rewards Points: 150
I want to have the entire roof removed in one day. 1200 sq ft. I hope there is a proper tool for this, let me know if you can. Thanks.
No loose gravel, took care of that already. Didn't want it going into the gutter.
Anyone have any help on the membrane?
Thanks.
Old 04-04-2010, 11:10 AM   #6
Rewards Points: 150
To The Top for the weekend. Anyone else have any input. Thanks.
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 06:01 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
New Roof needed .....only 8 years old!!! unhandy7 Roofing/Siding 9 11-18-2005 03:52 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
