Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-08-2007, 12:09 PM   #1
Diesel Fitter
roof coatings
Hello all,
Can I use the silver, reflective, roof coating on a rubber roof.
If Its not a blanket question, let me know what you need to know, thanks!
mikemy6 is offline   Reply With Quote
Old 07-08-2007, 10:18 PM   #2
roof coatings
Is it leaking?
can you post a photo of the roof?
redline is offline   Reply With Quote
Old 07-09-2007, 02:45 AM   #3
roof coatings
May i ask a question ? ok Thank You
I just had my Flat Roof done down here in Hollywood FL, Its All FLAT it was 1400 SQ feet They Used ,
1 ply Tin tab Down of GAFGLAS #75 Base Sheet
Then Came On Top Of That With GAFGLAS PLY 4 TWO Layers,
Then Hot Moped 1 ply of GAF Ruberoid Mop Membrane Tough Resilient Modified Bitumen Surfaced With White Granules.
The Roof Has Two Areas Where There Is Ponding Water But Go Away In 48 hours
They Was A little Sloppy With The Tar.
My Two Questions Are, Can I Coat This Roof White And If So What Should I Use For Ponding Water And Tar? And Is It A good Idea ? Should I coat The GAF Ruberoid Mop Membrane Tough Resilient Modified Bitumen Surfaced With White Granules? I Just Want A Nice Looking Roof, Thanks
And Is This A good Roof System ?
I Will Attach Some Pictures Ok
JJ Florida is offline   Reply With Quote
Old 07-09-2007, 05:29 PM   #4
Diesel Fitter
roof coatings
Hey Red,
No leaks
No pics.
It's black
I'm just looking to reflect some sun off a less than 2" pitched roof.
Thank You!
Old 07-19-2007, 09:21 PM   #5
roof coatings
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 08:28 AM
flat roof leak snikda9 Roofing 16 01-26-2006 05:25 PM
Flat Roof Replacement Quote Questions rocketmahn Roofing 1 01-02-2006 07:01 PM
