-   -   roof coatings (http://www.diychatroom.com/f9/roof-coatings-9735/)
mikemy6 07-08-2007 11:09 AM
roof coatings
Hello all,
Can I use the silver, reflective, roof coating on a rubber roof.
If Its not a blanket question, let me know what you need to know, thanks!
redline 07-08-2007 09:18 PM
Is it leaking?
can you post a photo of the roof?
JJ Florida 07-09-2007 01:45 AM
Roof Coating
1 Attachment(s)
May i ask a question ? ok Thank You :):)
I just had my Flat Roof done down here in Hollywood FL, Its All FLAT it was 1400 SQ feet They Used ,
1 ply Tin tab Down of GAFGLAS #75 Base Sheet
Then Came On Top Of That With GAFGLAS PLY 4 TWO Layers,
Then Hot Moped 1 ply of GAF Ruberoid Mop Membrane Tough Resilient Modified Bitumen Surfaced With White Granules.
The Roof Has Two Areas Where There Is Ponding Water But Go Away In 48 hours
They Was A little Sloppy With The Tar.
My Two Questions Are, Can I Coat This Roof White And If So What Should I Use For Ponding Water And Tar? And Is It A good Idea ? Should I coat The GAF Ruberoid Mop Membrane Tough Resilient Modified Bitumen Surfaced With White Granules? I Just Want A Nice Looking Roof, Thanks
And Is This A good Roof System ?
I Will Attach Some Pictures Ok
mikemy6 07-09-2007 04:29 PM
Hey Red,
No leaks
No pics.
It's black
I'm just looking to reflect some sun off a less than 2" pitched roof.
Thank You!
JJ Florida 07-19-2007 08:21 PM
Roof Coating ??
