Roof Coating A Torch Down Roof. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-20-2010, 01:53 AM   #1
Roof Coating a torch down roof.
What is the best product to use as a coating on an old but not leaking torch down roof? Is a primer recommended? I had a out building with a torchdown roof coated with a sno-coat product and the snocoat seems to be losing its bond. Would a petroleum or polyurethane based product be best over a torchdown? N. Zeller
N. Zeller is offline   Reply With Quote
The Following User Says Thank You to N. Zeller For This Useful Post:
Vikidin (08-20-2010)
Old 07-21-2010, 06:28 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
I like elastomeric products.
seeyou is offline   Reply With Quote
Old 07-27-2010, 02:03 PM   #3
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Are you coating for UV or are you coating to extend the life of the roof? This may answer some of your questions about the processes and products available... Roof Coating
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
The Following User Says Thank You to Grumpy For This Useful Post:
Old 08-20-2010, 08:18 PM   #4
We have 56 attached units where the torch down is between units.
12 are 2 years old, the balance are over 10 yrears old. How opften should they be resealed.
Vikidin is offline   Reply With Quote
Old 08-20-2010, 08:39 PM   #5
Like Grumpy asked,is it for uv protection or something to seal?Two different animals
johnk is offline   Reply With Quote
Old 08-21-2010, 09:55 AM   #6
As you can tell, Roofing is not my area of expertise
I have just taken over the duties of Chairman of our Buildings and Roads Committee at our Condominium Association. On this years budget there was provision for sealing torch down.
No one here seems to know specifically why.
How do I tell if the areas need it and what is the difference between UV protection sealer and, leak proof sealer?
Old 08-22-2010, 01:56 PM   #7
Residential Roofer
Slyfox's Avatar
If the sections of roof are not leaking or showing severe wear & tear than you could simply use something like a non-fibered aluminum coating.
It's pretty much just a paint job that will keep the roof out of the direct hit of the sun, which will help to increase the life span of the roof or at least help to get the expected life span from the roof.
If there are already leaks or severe wear & tear signs present then you would want to use some thing like Fibered-Aluminum coating.
This material is brushed on just like the non-fibered but it will seep into the material and bond with it.
Before doing either method you need to inspect the roofs and determine which to use, then there is prep work needed before it's applied such as a cleaning of the surface, etc.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 08-23-2010, 01:29 PM   #8
Grumpy's Avatar
Rewards Points: 540
I've never had good results with the fibered stopping any kind of leak. Yes the fibered aluminum coating is a better product than no fibered, but if you want to stop leaks you will need to do the prep work. If you choose to use an aluminum roof coating similiar to the junk on the shelves at home depot, expect to be painting every 3-5 years... just like any exterior paint job.
That's why I prefer elastomerics when it comes to leakage. Yes prep work is a must, but I have had good results with various professional grade elastomerics, not the junk on the shelf at home depot which is nothing more than house paint. The type of elastomeric to be used would depend on the pitch of the roof. If there is no standing water, an acrylic would be most cost effective. If there are ponds or standing water of any kind, then you should opt for a solvent based or urethane.
Old 08-24-2010, 04:26 PM   #9
Inland Coatings
have you looked into Inland Coatings RC2000
JAG EXTERIORS is offline   Reply With Quote
What's the best aluminum coating for a Torch down roof? quigleybmd Roofing/Siding 0 04-17-2010 05:28 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Coating over torch down before new decking bobhpete Roofing/Siding 2 05-17-2008 08:39 PM
coating torch down roof Betsy G Roofing/Siding 4 10-14-2007 11:40 AM
Reflective Coating on Flat Roof MelindaA Roofing/Siding 3 01-05-2006 05:08 AM
