roof coating
Chemically, physically, lengevitally (is that a word?) polyurea is hands down the winner here.
I have done many types of roof coatings, and NONE of them stand up to long term watersoak (ponding) like polyurea. It is a true vapor barrier. Water does not permeate through it, unlike asphalt emulsions, elastomeric acrylics, etc. Those coatings are known as breathers, and breathers allow water vapor transmission, which leads to chalking and mil thickness loss in a short period of time.
Polyurea may be a little more expensive initially for a ten year warranted system, but you can get a 48 mil Average Dry Film Thickness membrane that outlasts the others, provides ample elasticity for metal roofing, will standup to indefinite watersoak, and, in fact mil for mil, polyurea is LESS expensive.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
Reason: Semantics
