Is A Roof Cap Necessary Or Aesthetic? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-28-2009, 11:24 PM   #16
MJW
I have a few hunches, but I'll wait for the pics..............
MJW is offline   Reply With Quote
Old 12-29-2009, 01:11 AM   #17
It depends where the 2 roofs join.Is it at a ridgeline or is it actually the same roof that you share?If it was a ridge,a cap would be a must IMO.If it was the same roof I wouldn't do a cap,but rather a tie-in.I'll wait for pics..Did I make sense?
johnk is offline   Reply With Quote
Old 12-31-2009, 10:59 AM   #18
Dave The Roofer
Dave The Roofer's Avatar
Send a message via AIM to Dave The Roofer
Do you cut your own cap or use the pre-made
Originally Posted by Bob Mariani View Post
Functional.... each half of the cap is sealed to the other shingles
Do you guys cut your own caps or use pre-made cap?
Dave The Roofer is offline   Reply With Quote
Old 12-31-2009, 12:20 PM   #19
the roofing god's Avatar
Send a message via MSN to the roofing god
sounds like a townhouse with shingle roofs going from front or rear to a peak at the center(ridge/shared with neighbors)that would have capping,what the lady is more likely referring to is a sidelap going up the roof,It does sound acceptable in that situation
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
