Hello Everyone,
I live by New Orleans, LA.
At the last herricane season my roof was damage a little and we are thinking to do the whole roof replacement. But I'm very much confuse about the brands.
I'll be highly appriciated if someone can advise me what brand should I choose. My roofer gave me below options:
Tamko
Owens Corning
GAF.
He is also suggesting about adding ridge ventilation. Pls note that my roof area is around 38 square and I already have 2 power vents, but the roofer is telling me that is note enough and adding of this ridge vents is required by the shingles co other wise they will not owner the warranty.
Pls also advise if you have both kind of vents, power and ridge, together on the same roof, will it hurt anything.
With ridge vents there is no other vents needed on top of the roof.
Why do you think you need a new roof?
Possible it was just installed wrong to begin with and just needs a few more nails.
I already have the power ventilations fan. On two sides of my house the surface is not flat, I can easily see the dips/waves. And during the last hurricane, many shingles teared off.
Soofit Venting: if you talking about things with the holes by the siding, yes we have that, I would say 30 years and they are rectangular shape, 3 dimensional if I'm not mistaken. Thanks,
A ridge vent will vent the whole roof not just a circle like a power vent does.
Uses no power, no moving parts to fail.
Looks a whole lot better.
If you go with a ridge vent all other roof mounted vents and gable vents if there is any need to be removed or blocked off.
At the last steep roof seminar I attended, the shingle manufacturers said that good continuous ridge and soffit venting is best. Fans are not needed if you have that. The key here is good. I do not like the rolled up type of ridge vent, and soffit venting has to be kept clean and unless it is continuous, you are not getting enough air in.
Thanks,
I have both the choices, keep the power vents or the ridge vents or both. And I clearly understand that two types of vents is not recommended on a single roof. But if I have to choose b/w the ridge or power which is more afficient and recomended. Just to add the redge size on my roof is only 12ft. is it good enough to for the area of 40sq?
Reg my current power vents: How could I detirmine that it is good enough for my roof and house.
They will honor the warranty even though you have inadequate ventilation but it is drastically reduced.I don't like the roll type either.,I prefer the 14-"1/4" ridge vent with an external baffle.I also recommend hand nailing the ridge vent and cap. I feel hand nailing the products in high velocity wind prone areas also provides some confidence in the material in the event of high velocity winds.
As its been said,,,its equally important to find a qualified roofer to install your product as it is to find a quality product.Certainteed,GAF and Tamko is my choice for materials in my region.
Your question What is slivers? Slivers are those little shreds of fiberglass that get stuck in your fingers.And lemme tell you they hurt.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
