Roof With Bent Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-07-2010, 09:50 AM   #1
Rewards Points: 184
Roof with bent shingles
My roof has shingles and a lot of the corners are bent.
Should those be replace?
Were they likely caused by wind/storm damage?
TIA
abefroman is offline   Reply With Quote
Old 08-07-2010, 09:52 AM   #2
the Musigician
DangerMouse's Avatar
Not too sure personally, although I'd think as long as they're not broken and missing corners, why not just go up and use some roofgoop to glue them back down, (pitch allowing)?
DM
Old 08-07-2010, 10:13 AM   #3
Rewards Points: 184
DM
Good idea!
Is there a special glue to use for this or will something like gorilla glue work?
Old 08-07-2010, 10:18 AM   #4
the Musigician
In my case, I have some black roofing tar/adhesive here I'd put on it and weight it for a day, but I also have a 12/4 pitch, so it'd be easy, and I wouldn't have bricks rolling off the roof killing innocent bystanders.... Po)
DM
Old 08-07-2010, 03:16 PM   #5
Residential Roofer
Slyfox's Avatar
Shingles will curl at the corners when they get toward the end of there life span and sometimes it will happen pre-maturely due to poor ventilation.
If they are newly installed and have that issue it's due to, poor stocking of the bundles, poor installation of them or an actual faulty material.
A couple pictures would help to give a better guess.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 08-07-2010, 10:03 PM   #6
Slyfox is right. Just had to do new roof on our house. You may find a good roofing company around and get some prices then compare the cost of doing it yourself. Sometimes its easier to bite the bullet and pay the bucks to have it done!
diy_man is offline   Reply With Quote
Old 08-08-2010, 01:02 AM   #7
Doing This Way Too Long
Rewards Points: 532
use roofgoop to glue them back down?? You're not a roofer are you dangermouse?
OP, how old is your roof? Sounds like it's on the back end of it's lifespan.
OldNBroken is offline   Reply With Quote
Old 08-08-2010, 07:35 AM   #8
the Musigician
Since my first comment was "Not too sure personally.." I'd guess no.
DM
Painting New Roof Shingles to match old ones? Lgarced Painting 0 03-25-2010 08:46 PM
Epoxy roof sealant over shingles? P550 Roofing/Siding 15 04-11-2009 10:00 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof DIYInCT Roofing/Siding 2 11-23-2008 10:31 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
