Rolled Roofing Or Metal - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-14-2008, 10:03 PM   #1
rolled roofing or metal
There was an addition added on the back of my house before I bought it. It currently has rolled roofing on it due to the pitch. Can I replace it with metal roofing or dose that need a good pitch?
rick32 is offline   Reply With Quote
Old 10-16-2008, 03:58 PM   #2
Doing This Way Too Long
Rewards Points: 532
can't tell you without knowing what the pitch actually is. Can give you a few tidbits in the meantime though.
1. Pretty much anything will be better than rolled roofing.
2. "metal roofing" is a very generic term. Really need to know the pitch.
3. I personally don't recommend any lower end system on anything under a 3/12
It all depends on how much quality and how good a roof you want to put on this deck. Based on what little info you provided, no one can really give you any specific advice. A picture is worth a thousand words.
OldNBroken is offline   Reply With Quote
Old 10-21-2008, 08:42 AM   #3
pitch
Im not too sure how to calculate the pitch. The roof is about 13' and drops 2.5' from one end to the other. I plan on doing a compleet rebuild in the spring. I just wanted the best course of action.
Rick
Old 10-21-2008, 02:11 PM   #4
Do you have any photos of the roof and a side view showing how much it slopes that you can post?
Also, an easy way to determine the pitch/slope is by using a ruler and a small level. Hold the ruler with the level with the one end of it touching the roof at the higher point on the slope. Take a tape measure and measure the distance the front of the ruler, at the 12" mark, is above the roof on the lower sloped section.
That will give you the amount of "Rise" for every 12" of "Run".
Ed
Ed the Roofer is offline   Reply With Quote
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 06:48 PM
metal roofing nomoney Roofing/Siding 27 01-12-2009 09:29 PM
Matching Shingles and Rolled Roofing crankitup Roofing/Siding 2 01-31-2008 12:33 AM
rolled roofing alternatives? timtreva Roofing/Siding 1 09-13-2007 01:12 PM
Metal Roofing for Experienced Beginners rezroofers Roofing/Siding 3 06-20-2007 11:42 PM
