Rolled Roofing Leaking And Leaking - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-17-2009, 06:14 PM   #1
Unhappy
Rolled Roofing Leaking and Leaking
Hello All-So I have attached room and garage which had really old roofing on it... After a few roofing estimates (a whole other story)...Decided to do it myself with my friends. So stripped the old roofing off, repaired the ceiling spots that were rotted; did the #30 asphalt felt with the roofing tar stuff and 90lb mineral roofing. Now leaks really bad inside the attached room along the seem (checked where joins to the house) new flashing was installed... Any ideas would be appreciated. Thanks Much.
DIYNewbee is offline   Reply With Quote
Old 11-17-2009, 06:17 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
post a pic of the rooking job to give us a better idea what you are dealing with.
Old 11-23-2009, 06:30 PM   #3
Remodeling Contractor
My opinion- replace with a quality product. Rolled roofing is garbage and should be outlawed.
eisert is offline   Reply With Quote
Old 11-24-2009, 09:34 PM   #4
Household Handyman
Rewards Points: 1,408
I'm with "eisert", roll roofing will just sit on the shelf waiting forever for me to purchase any of it. I'm also with "bulitbob" as far as the pictures. Trying to help/give advice on something like this is difficult to say the least without pictures. Even if you have to borrow a camera or have someone else take the photos, we need pics. Thanks, David
Old 11-24-2009, 09:47 PM   #5
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
I wish I had an answer for you. I've been up on a few of these, and have no clue how the homeowner handled them.
My plan, for me to do the work, was to wait a year or two until the cement had set up and wasn't so gooey. Then, after it had hardened, yank it off and start again.
Pictures would help.
tinner666 is offline   Reply With Quote
Old 12-04-2009, 01:47 PM   #6
Commercial Roofing
AaronB's Avatar
Redo it with a real roof. Unfortunately for you, you get what you pay for.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 12-11-2009, 02:30 PM   #7
home builder
was it the old50# paper backed or the new typar with granules?............junk. go get a piece of rubber roofing
kubie is offline   Reply With Quote
Old 12-11-2009, 02:55 PM   #8
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
People think "rolled roofing" thats sold at the home center is for low slope roofs. ITS NOT
Sure, there are roofing materials designed for low slope roofs that come in rolls but its not the same thing by a long shot.
As suggested it may be time for the right product to be installed. Maybe, maybe, it can be salvaged but we cant tell without pictures. If its a flat or sorta flat roof you have the wrong product on it.
Brik is offline   Reply With Quote
Old 12-13-2009, 11:06 AM   #9
Roofing Contractor
Leftyho's Avatar
Hi,
Installed a lot of rolled roofing. Never had a problem. It is not for dead flat, any pitch it will work. Seen many of them last 20 - 30 years with the right maintence. I always gave a 8 year warranty. It would last that long without maintence.
Fixed alot that everyone said was shot. Extended the life another 10 year.
Leftyho is offline   Reply With Quote
Old 12-13-2009, 10:46 PM   #10
Pro Slate Roofer
tinner666's Avatar
That's good to know Lefty. I've only used it 3 times in 40 years. I have no idea how long they lasted. 1 was a gov. job.
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing/Siding 5 01-06-2009 07:51 AM
New 1yr Townhome with Leaking Roof! sijunk Roofing/Siding 9 08-08-2008 04:50 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
rolled vs. rubber roofing felix Roofing/Siding 4 03-01-2006 11:16 AM
