Rolled Roofing??? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-03-2010, 10:23 PM   #1
Question
rolled roofing???
I have a porch off the back of my house that has started to leak. On the bottom 4'. Im going to replace with new plywood, grace ice and water, and rolled roofing......ok the question is or are, putting down the grace shield first, then drip edge, can i use cement on the shield and then apply the rolled roofing ( that i would nail down through the shield)or do you have other suggestions. Lowes rep said to use rolled roofing because my pitch isnt that great 1-12, 2-12.The rest of the porch is in great shape with architechile shingles with no stains or leaks. Any help would b much appreciated.....Thanx in advance
us masonry is offline   Reply With Quote
Old 11-03-2010, 11:39 PM   #2
Rewards Points: 978
you shoudlnt do shingles with such a flat slope. if its a small area roll roofing should be fine. i am sure the other experts here may chime in. i am no expert. just speaking from experience
federer is offline   Reply With Quote
Old 11-04-2010, 03:41 AM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
You don't want rolled roofing or storm shield. Find a roofing supply house like BRADCO and get what you need to put down a SBS base sheet, an interply, and a cap sheet. The stuff is self adhering. A wagner heat gun would be an econominal DIY tool for heating the material.
tinner666 is offline   Reply With Quote
Old 11-04-2010, 07:55 PM   #4
sounds expensive...have only a space 4' x16' on the end of the roof. Thanx for trying to answer question.
Old 11-04-2010, 10:56 PM   #5
Well he did answer your question,with a very good solution.Do it your way(cheap).You get what you pay for.What do we know anyways,we only do it for a living
johnk is offline   Reply With Quote
Old 11-05-2010, 10:15 PM   #6
Doing This Way Too Long
Rewards Points: 532
I don't recommend rolled roofing for anything other than, well, actually I don't recommend rolled roofing for anything period. Certainteed Flintlastic SA or GAF Liberty SA are two fantastic DIY'er systems that, properly applied, perform extremely well in your situation.
OldNBroken is offline   Reply With Quote
Rolled Roofing Leaking and Leaking DIYNewbee Roofing/Siding 9 12-13-2009 09:46 PM
1927 Metal porch roof/Deck 4'x6' (EDPM or Rolled roofing). greenhornet Roofing/Siding 2 09-22-2009 09:49 AM
rolled roofing product charliebrown314 Roofing/Siding 1 03-12-2009 12:30 AM
Matching Shingles and Rolled Roofing crankitup Roofing/Siding 2 01-31-2008 12:33 AM
rolled roofing alternatives? timtreva Roofing/Siding 1 09-13-2007 01:12 PM
