Rolled Roof Replacement - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-26-2008, 12:59 PM   #1
Rewards Points: 26
Rolled roof replacement
I am going to be doing my grandmas roof and need some help with rolled roofing. I have done a couple houses with shingles but my grandma has a low sloped(3/12 or so) dormer roof on the back side of her house that has rolled roofing on it now. It is about 18-20 inch wide rolls that must be self adhearing or some kind of adhesive used. First what is the best way to remove the old rolled roof? Second, how do i install a new rolled roof? Looks like you just roll it out but i'm sure there is more to it than that. Any help with this will be greatly appreciated.
ponch37300 is online now   Reply With Quote
Old 08-28-2008, 12:06 AM   #2
Rewards Points: 26
Anyone have any experience with rolled roofing that can give any advice? thanks
Old 08-28-2008, 08:17 AM   #3
Residential Roofer
Slyfox's Avatar
You need to be a little more specific.
When you say roll roofing, I think of 90# material which in my opinion is not an acceptable roof covering.
There are a few systems that are self adhering single ply, which you basicly roll out.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 08-28-2008, 11:25 AM   #4
Rewards Points: 26
It is about 30" wide and looks almost like a shingle material but in a roll form. It is what is on the roof now and grandma would like it back on there. Couple of questions, how easy is the current stuff going to be to rip off, any tricks or tips on tear off? Should there be tar paper under it? Starter strip? How to fasten it, i've read some different opinions on this? How to flash around vent pipes and the square air vents? Thanks for any advice with this. I know it's not the best material but it's what grandma wants and can afford right now and she says the last stuff lasted a while. Thanks
Old 08-29-2008, 10:01 PM   #5
It is probably SIS.
Seventeen Inch Sevage, leaving 19 inches exposed.
It is installed with an asphalt adhesive.
If done properly to a primed surface, it may not detach easily, unless you get at it in the coldest time of the day where you reside.
Spud bars and A-holes and Elbows. Keep plucking away at it. It may just be partially adhered and/or just nailed in place witha bit of adhesive at the overlap edge.
Ed
Ed the Roofer is offline   Reply With Quote
Old 08-31-2008, 10:52 AM   #6
Rewards Points: 26
Thanks for advice on tearing off Ed. Any advice on the correct way to put new on? Should there be tar paper under it? Starter strip? How to fasten it, i've read some different opinions on this? How to flash around vent pipes and the square air vents? Thanks for any advice with this.
Old 09-02-2008, 07:42 PM   #7
My last house had an attached garage with a 1/12 roof.
Originally, it was a sevedge roof, that i was able to remove, using a shovel.
The replacement roofing came as a roll 32" wide.
This roofing was peel and stick. No nails!
there was 2 sheets of waxy paper on the back, running longitudinal, that is peeled off when installing.
A adhesive is painted on the decking and allowed to dry until its walkable.
The first row was laid out with the paper still on the back!
Then the topside was folded back over the bottom, exposing the top paper. Which is removed.Then it was rolled back to its final position, where it bonded to the adhesive.
Then the bottom section was folded over the top and its paper removed. Then, it was rolled back down and into position.
A rubberized caulk bead is then run along near the top edge, to seal the second course.
The second course is installed in much the same manner.
This roof was not cheap.
Old 09-03-2008, 11:17 AM   #8
Check out the Peal and Stick Modified Bitumen products that are available at a local roofing supply house and follow the instructions.
For penetrations, a "Tight Seal" can be made by taking a 12" x 12" square piece of material after the full roll of membrane has gone past the penetration, and by using a hammer, you can tap the outside diameter of the pipe circumference into this target patch.
Then, slide it down onto the field material and stick it in place.
Ed
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 06:01 PM
