Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-07-2009, 05:48 PM   #1
roll rubberized roofing
How do you apply rubberized roll roofing and is it better than regular asphalt roll roofing?
Or what is the best method for roofing a flat roof?
rdayzz is offline   Reply With Quote
Old 07-07-2009, 07:12 PM   #2
Super Moderator
Each flat roofing product has it's own Pro's and Con's for various applications.
Could you please describe the flat roof you are referring to a bit more, with total size and amount of roof top penetrations and what, if anything, it ties into?
Also, several photos posted of the intended area to be roofed would be helpful.
Finally, you are probably NOT referring to any type of Rubber Roofing, if you are thinking of it in one man usable roll sizes, but more likely, Modified Bitumen, which is an asphaltic product with the bituminous material in a roll for, with a reinforcement scrim, which then either gets instaled by open heat souces, such as a flame torch or electric hot air welders, or as a self adhesive roll roofing membrane.
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing 9 09-13-2009 06:32 PM
Roll out roofing on my shed. stevez Roofing 2 05-14-2009 06:12 AM
Modified roll roofing problems chilltrain1 Roofing 4 04-19-2009 04:08 PM
Modified Bitumen or roll roofing Ricardo Roofing 7 05-08-2008 07:38 AM
Roll roofing material RedDawg454 Roofing 8 05-03-2007 07:52 AM
