roll rubberized roofing
How do you apply rubberized roll roofing and is it better than regular asphalt roll roofing?
Or what is the best method for roofing a flat roof? |
Each flat roofing product has it's own Pro's and Con's for various applications.
Could you please describe the flat roof you are referring to a bit more, with total size and amount of roof top penetrations and what, if anything, it ties into? Also, several photos posted of the intended area to be roofed would be helpful. Finally, you are probably NOT referring to any type of Rubber Roofing, if you are thinking of it in one man usable roll sizes, but more likely, Modified Bitumen, which is an asphaltic product with the bituminous material in a roll for, with a reinforcement scrim, which then either gets instaled by open heat souces, such as a flame torch or electric hot air welders, or as a self adhesive roll roofing membrane. Ed |
| All times are GMT -4. The time now is 01:34 AM. |
