Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-21-2007, 06:51 PM   #1
Roll roofing material
The flat roof over my carport currently has a black rubberized roof. (maybe torch down?) Can I install rolled roofing over this material?
Is so whats the best way to install. The directions say to nail along the 4" overlap so all nail holes are covered by the next row. But it dosnt really specify if the whole area the roll roofing covers needs tar. Also says to use flashing cement. So I bought a 5 gall bucket to start with.
Any help would be appreciated.
RedDawg454 is offline   Reply With Quote
Old 04-22-2007, 12:53 AM   #2
why would anyone install roll roofing period?
RooferJim
RooferJim is offline   Reply With Quote
Old 04-22-2007, 09:48 AM   #3
Commercial Roofing
AaronB's Avatar
I wouldnt waste the money on 90#. Why save money now just to pay again in a year or two?
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-22-2007, 01:56 PM   #4
Super Moderator
You will cause more problems on the flat roof than if you just left it alone and as is.
90 # roll roofing is best used for a cheap roof job on a substantially pitched roof, not as a flat roof application, unless it is being hot mopped in hot asphalt as a cap sheet for the preceeding plies of built up roofing felts.
Ed
Ed the Roofer is offline   Reply With Quote
Old 04-22-2007, 08:19 PM   #5
Ok, Whats your suggestions then. Ive only run one row, that can easily be removed. (well has to be removed now, due to material bubbling)
Thats all i usually see on flat roofs here in Florida, thats why i was going to install it.
My friend was telling me about a mesh material you lay down, and coat with some type of white sealant. Ive seen this type of material on commercial buildings flat roofs.
Old 04-30-2007, 08:41 PM   #6
find out exactly whats on there now,if it is torch-on compatible,hire a roofer to put on a granulated cap sheet
johnk is offline   Reply With Quote
Old 05-01-2007, 05:04 PM   #7
Commercial Roofing
AaronB's Avatar
the white "sealant and mesh" stuff is garbage. It washes of after a matter of time if ANY water sets on it. Seams can retain a little water, depending in the pitch. Reflectivity is all theyre good for, IMO.
Old 05-02-2007, 12:44 PM   #8
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Yea, the roll roofing you describe is garbage and bad for low slope roofs.
Unfortunately you just made the problem wors by putting nails through what you already have. Sorry.
Torch down is also 'roll roofing' as it comes in rolls. Like another said, if your base is solidly attached, and compatible with a torch down, granule impregnated top sheet, then that is a very good way to go. EDPM is another good low slope solution and is more DIY friendly. You wont find a torch down top sheet or EDPM at your home center, most likely.
Brik is offline   Reply With Quote
Old 05-03-2007, 07:52 AM   #9
Commercial Roofing
AaronB's Avatar
ALL roofing membranes are then roll roofing, except polyurea.
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing 9 09-13-2009 06:32 PM
roll on roofing system jcherry Roofing 6 08-04-2007 11:52 AM
Which Roll roofing product is least susceptible to mistakes by inexperienced roofers? boyblue Roofing 3 07-22-2007 06:03 PM
Roll roofing again LOL! pmaru77 Roofing 12 06-05-2007 08:43 PM
What roofing material is right for me? Grumpy Roofing 0 07-07-2004 08:41 PM
