Roll Roofing Advice Needed - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-20-2013, 08:49 AM   #1
Quackerjack's Avatar
I am tasked with re-roofing my retired aunt's garage and I need some advice please. It currently has 2 layers of mineral surfaced roll roofing that is worn and leaking. The pitch is just under 2:12. With a search of the internet, I see that quite a few people poopoo roll roofing.
This has to be a DIY job and we cannot afford to hire roofers to torch in EPDM roofing.
I have never done this before but I have some experience de-shingling a roof, helping with a shingling job and I am confident I can follow instructions.
1) Is there an alternative to roll roofing that is affordable and able to be installed by a DIYer?
2) Is there any reason I should or should not install roll roofing over the old roll roofing? I would have to flatten the ripples in the old roofing.
3) Having installed the roll roofing would anyone recommend for or against using a white latex/rubber coating on top of the finished application (like this: DuRock Coolflex)?
Any suggestions and help would be very appreciated.
Here are some pics:
[/url]
Untitled by Whippersnapper12, on Flickr
Quackerjack is offline   Reply With Quote
Old 05-20-2013, 10:25 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Sure is. Tear all that off, and get a nailable SBS base, interply and cap sheet.
Here are the GAF instructions. http://www.gaf.com/Residential_Roofi...structions.pdf
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Quackerjack (06-27-2013)
Old 05-20-2013, 10:28 AM   #3
Rewards Points: 13,250
There is no way to just go over that mess.
Plan on having to replace some of the sheathing since it's been leaking.
Old 05-20-2013, 08:58 PM   #4
Roofmaster
Rewards Points: 2,172
You cannot torch EPDM. It is a cured elastomer, like an inner tube, not a Modified Bitumen
The guys are correct. Tear it all off to the deck, recover with 1/2 inch plywood, Nail a G2 Glass base sheet with cap nails and install GAF Liberty or some other peel and stick. You can also use cold process, Do not torch. You will burn down gram-ma's garage. You will need to get some gravel stop and drip edge bent up by a local sheet metal shop.
.032" Aluminum Minimum.
PS Wear a good mask when you tear off, there may be some AB in that mix. It kind of looks like it.
The Following User Says Thank You to jagans For This Useful Post:
Tags
roll roofing
Mineral Guard Roll Roofing toeey1 Roofing/Siding 4 06-05-2012 10:35 PM
Subfloor Overhaul - Advice Needed kadams2345 Flooring 39 11-19-2011 02:02 AM
Buying a home - water softener advice needed before closing Hoops Plumbing 4 11-02-2011 09:40 AM
Lots of advice needed - exterior painting. lazzlazz Painting 1 06-20-2011 08:56 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 07:09 AM
