Ridge Vents VS Standard Roof Vents - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-26-2012, 09:26 AM   #1
ridge vents VS standard roof vents
I am getting my roof done and can't decide which one to go with. I like the ridge vent look better, but my roofer has told me that he has repalced alot of ridge vents to do leaks, mostly water blowing in from rain and snow. I live in southeastern Michigan any suggestions.
goodcop047 is offline   Reply With Quote
Old 05-26-2012, 09:58 AM   #2
the Musigician
DangerMouse's Avatar
Ridge vents have their pros and cons, but the decision is up to you what you end up with. I can tell you I just added some turtle/mushroom vents to my roof no problem as I found the ridge vent to be inadequate.
(P.S. you misspelled misspelled. )
DM
Old 05-26-2012, 10:00 AM   #3
RFN-4A-LVN
Roofmaster417's Avatar
It might be the type that was used that was creating the problem.A RidgeVent without an external baffle is notorious for sponging water.
Since you are in a high winter precipitation area I recommend this product or something similar with external baffles.
RidgeVent over standard vents any day.
http://www.gaf.com/roofing/residenti...w-country.aspx
Roofmaster417 is offline   Reply With Quote
ridge vents vs. box vents vs. turbine vents redaws Roofing/Siding 12 03-12-2012 09:48 PM
Ridge vent or Mushroom roof vents ? Clem7864 Roofing/Siding 1 10-19-2011 11:00 PM
Ridge vents and roof vents jerry1967 Roofing/Siding 4 06-07-2010 05:40 PM
Need Help with Ridge Vent on Unusual Roof MSBOY Roofing/Siding 1 03-24-2010 09:46 PM
Roof ridge board/beam material and sizing. Roy Rowlett Building & Construction 11 07-08-2009 08:18 PM
