Ridge Vents, Soffit Vents, End Gable Vent Confusion. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-01-2012, 12:29 PM   #1
Ridge vents, soffit vents, end gable vent confusion.
I have soffit vents and gable vents. I'd like to have ridge vents installed. I've read where gable vents should be closed off if ridge vents are installed but two roofers I've talked to say it is not necessary to block off the gable vents. So which way do I turn? House is 40 years old. Do I really need ridge vents? Will they save me money?
joemill is offline   Reply With Quote
Old 04-01-2012, 01:48 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
The reason to vent attic spaces is remove moisture. Air sealing the ceiling plane and insulating properly is how you save money. If you have no moisture/mold issues, then adding ridge vent to the current system MIGHT cost you money by depressurizing the attic and causing conditioned air to be pulled into the attic.
seeyou is offline   Reply With Quote
Old 04-01-2012, 01:52 PM   #3
Registered User
Rewards Points: 5,482
Where are you located?
Gary
Old 04-01-2012, 04:48 PM   #4
Remodeling Contractor
The best advise on venting comes from those trained in new building science methods. Those that are in the know will tell you to close of the gable vents when adding ridge vents. The manufacturers of ridge vents also give this advise.
Old 04-01-2012, 05:18 PM   #5
Rewards Points: 626
One can never ever have enough ventilation for your roof. I have both gable and ridge vents because of the size of my heat load for the Attic. I want as much heat to get out in the summer so my roof does not fail before its time!
Nailbags is offline   Reply With Quote
Ridge Vent with roof vents and Soffit vents apquery Roofing/Siding 10 08-08-2016 09:28 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Ridge vent considerations sglt Roofing/Siding 8 10-28-2010 06:26 AM
Do I need the gable vents bjakeski Roofing/Siding 4 08-17-2010 05:17 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
