Ridge Vents - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-19-2009, 03:27 PM   #1
Ridge Vents
Can ridge vents be used on a hip roof? If so, which brand, type, or any other info. Input is greatly appreciated. Thank you for your time. Mikero
Mikero is offline   Reply With Quote
Old 06-19-2009, 04:17 PM   #2
MJW
Yes there is a ridge vent that works on hips. We have installed it before, but only once, and I can't remember what brand it was. Ask at your supplier.
MJW is offline   Reply With Quote
Old 06-19-2009, 04:20 PM   #3
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
I am not a fan of vented hips. I have seen a few products, but am very hesistant to use them for fear of wind blown moisture infiltration.
Please do not use a ridge vent on your hips!
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 06-19-2009, 07:36 PM   #4
I only installed the vents on a hip one time, due to the structure beneath having vaulted/cathedral ceilings.
The material was from Owens Corning and I think it was called Vent Sure.
There was another one I found, but my suppliers did not carry it, from Mid-Americe.
Generally, it is NOT advised to vent the hips of that style structure, but better to beef up the Intake Ventilation continuously and then using either an Electric Powered Attic Ventilator or a Solar Powered version.
Ed
Ed the Roofer is offline   Reply With Quote
Ridge vents and/or fan? mama2girls Roofing/Siding 20 05-27-2009 07:12 AM
I am ready to get rid of the ridge vents PerpetuallyRepairing Roofing/Siding 20 04-15-2009 09:17 AM
Attic venting - Ridge vents or fans? jebmke Roofing/Siding 16 07-03-2008 11:03 AM
Gables and ridge vents not giving ventilation Texas Heat Roofing/Siding 4 04-25-2008 01:39 PM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 09:47 AM
