Ridge Vents - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-20-2013, 10:14 AM   #1
Rewards Points: 37
Ridge vents
Bought a house a few months ago, and in getting ready for winter, noticed an issue with ridge vents along my 2 ridges. Had 2 different roofers look at, and they both said that when the roof was replaced - within the last 5-10 years - instead of using 2 1/2 inch nails on these ridge vents, it looks like they went ahead and used the 1 1/4 inch nails from their nail gun, and the ridge vents are starting to pull away, which is creating a gap you can put your fingers into.
Both recommended replacing the ridge vents with new ridge vents. They said they could not just replace the 1 1/4 inch nails with the 2 1/2 inch nails and use the old ridge vents.
I want to make sure they are putting in quality ridge vents and using the right nails this time so they will last. I currently have architectural style shingles.
One roofer said he would be using "GAF Cobra type" ridge vents. Are these a quality vent? If not, what would be some names of quality ridge vents?
I had heard that with installing the ridge vents that maybe "ribbed" nails would be best, but the one roofer said that he would be using 2 1/2 inch roofing nails, because the manufacturer of the ridge vents recommends this type instead of the ribbed. Is this the case? I just want to make sure they stay down, of course, this time.
He also said I had a choice to either have him cut the ridge caps needed from 3 tab shingles, which he said was up to building code and 90% of roofs are installed this way, or I can get the pre-cut ridge caps which are double thickness and supposedly are more durable. He said in his experience he hasn't seen any difference in durability, but it is up to me. Is it worth spending the extra money on the pre-cut ridge caps?
Any other suggestions would be appreciated...
Thanks!
kah5683 is offline   Reply With Quote
Old 10-20-2013, 10:30 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,964
Thanks!
Cobra vent is crap.
To quote Joecaption...it looks like a snake trying to swallow a rat.
Be sure to use a proper, rigid, ridge vent. GAF Snow country and AirVent Shingle vent 2 are both good with the latter probably being the better.
When they are attached to the rafters or trusses, they don't usually pull out much but a ring shank nail is what you are referring to.
Just use shingle caps. They are about as cheap as 3 tabs now and look much better.
Have them run the ridge vent (not the cut) to the edge of the roof as it looks better that way.
Old 10-20-2013, 10:35 AM   #3
Rewards Points: 13,300
I would not use Cobra style vents on my dog house. They just do not allow enough air flow.
Both my local shingle suppliers and even the local box stores all stop stocking it because of all the complaints.
2-1/2" galvanized roof nails will work fine.
Go for the real hip and ridge caps, 3 tabs used as caps can crack and are far more likely to fail.
There 90% done that way because there cheaper, not because they work.
http://www.airvent.com/homeowner/pro...ngleVent.shtml
Ridge vents are useless without the proper amount of soffit venting.
Thinking of installing ridge vents... calikingTX Roofing/Siding 10 07-30-2012 12:02 AM
Have Gable/Soffit Vents Contractor Suggest Ridge Vents sallygump50 Roofing/Siding 3 05-11-2012 11:56 AM
Ridge vents, soffit vents, end gable vent confusion. joemill Roofing/Siding 4 04-01-2012 06:18 PM
Atic: Adding Intake and Exhaust Vents (Maybe Ridge) arcane Roofing/Siding 9 07-22-2010 07:20 PM
I am ready to get rid of the ridge vents PerpetuallyRepairing Roofing/Siding 20 04-15-2009 10:17 AM
