Ridge Vents - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-10-2012, 08:00 PM   #1
Ridge Vents
Can a ridge vent be installed after a roof is completed?
handywoman12 is offline   Reply With Quote
Old 09-10-2012, 08:07 PM   #2
Rewards Points: 12,790
That would be doing it backwards, but a ridge vent can be added anytime.
Your going to have to go back and remove the ridge cap shingles, remove enough shingle so you can snap a line and cut back the sheathing 1-3/4" from the center of the roof on both sides, install the ridge vent then the new ridge caps.
You need to leave about 12" on the ends with just the old shingle caps. (ridge vent is never suppost to be run all the way to the ends of the roof)
Old 09-10-2012, 10:33 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 822
Yes.
More importantly, do you have intake air?
What is the current venting?
Old 09-11-2012, 07:32 AM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Actually, you leave the uncut wood and shingles over the ridge at the ends, and run the RV all the way to the ends. Going over cap at the ends actually leaves a slight ramp that will allow water to follow the slope or the last cap under the RV.
It also gives a smoother, more polished appearance than that slight rise on the ends by going over to layers of cap.
http://www.albertsroofing.com/Ridge%20Vent%20Detail.htm
tinner666 is offline   Reply With Quote
Old 09-11-2012, 02:49 PM   #5
Rewards Points: 43
Originally Posted by Windows on Wash View Post
Yes.
I am finding out how important the soffit vents are for intake air. In preparation for my new roof with ridge vent, I am adding 17 more 16x4 soffit vents.
I added 8 vents to the low section that I could reach by step ladder, and I can really tell a difference in the attic!
And the existing ventilation wasnt lame by any means, with 41 vents spaced 48" apart.
Al
AlleyG is offline   Reply With Quote
Thinking of installing ridge vents... calikingTX Roofing/Siding 10 07-30-2012 12:02 AM
Have Gable/Soffit Vents Contractor Suggest Ridge Vents sallygump50 Roofing/Siding 3 05-11-2012 11:56 AM
Ridge vents, soffit vents, end gable vent confusion. joemill Roofing/Siding 4 04-01-2012 06:18 PM
Atic: Adding Intake and Exhaust Vents (Maybe Ridge) arcane Roofing/Siding 9 07-22-2010 07:20 PM
I am ready to get rid of the ridge vents PerpetuallyRepairing Roofing/Siding 20 04-15-2009 10:17 AM
