Ridge Venting Vs Turtle Vents In Snow Conditions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-05-2011, 11:21 AM   #1
Ridge venting vs turtle vents in snow conditions
OK so why do I get so many different opinions on this subject from roofing contractors what is the best option? I have good soffit vents and turtles but I want to go ridge and also add side wall gable vents. Snow covering both types of roof vents is the consideration. Thank for the help.
fabio is offline   Reply With Quote
Old 02-05-2011, 03:15 PM   #2
Residential Roofer
Slyfox's Avatar
The reason you get so many different opinions is because both ridge & turtle vents work when properly installed.
I lean toward ridge vents myself because I see them as being aesthetically the better choice.
Far as gable vents go, your going to find mixed opinions there as well.
I always recommend not using them in cases where proper intake, unobstructed air flow and exhaust is/can be achieved with out them.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 02-05-2011, 03:17 PM   #3
Rewards Points: 1,088
I would remove the turtle vents and either just add a long ridge vent, or add gable vents with a fan on one of the gable vents.
handy man88 is offline   Reply With Quote
Old 02-05-2011, 09:10 PM   #4
old timer
Because many roofing contractors are misinformed on the subject?
Ridge, turtle, power, gable, and soffit vents all work well together, and in the case of heavy snow covering some of these vents, are preferable. Depends on the situation.
dmc@RCR is offline   Reply With Quote
Atic: Adding Intake and Exhaust Vents (Maybe Ridge) arcane Roofing/Siding 9 07-22-2010 06:20 PM
Ridge vents? klab Roofing/Siding 7 06-28-2010 02:05 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
I am ready to get rid of the ridge vents PerpetuallyRepairing Roofing/Siding 20 04-15-2009 09:17 AM
Attic venting - Ridge vents or fans? jebmke Roofing/Siding 16 07-03-2008 11:03 AM
