Ridge Vent W/ Roof Louvres? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-29-2009, 05:19 PM   #1
ridge vent w/ roof louvres?
My house has a ridge vent w/ 3 roof louvres on the back side. Are the louvres taking away any benefit of the ridge vent? Can I just cover them up inside the attic to force air out the ridge vent?
byocum is offline   Reply With Quote
Old 08-29-2009, 06:07 PM   #2
Yes you can and should, especially if you have not experienced the benefite of the stack effect flowing from the eave/soffit vents out of the ridge vent.
Do you have enough NFVA from your Intake Ventilation source to make it work as prescribed though?
Ed
Ed the Roofer is offline   Reply With Quote
Old 08-30-2009, 09:58 AM   #3
old timer
Not at all.
http://roofingcontractorreview.com/R...cuit-Myth.html
That would just reduce the amount of available exhaust area.
dmc@RCR is offline   Reply With Quote
Old 08-31-2009, 06:17 PM   #4
more background
Well, I guess I have 2 different answers. Perhaps more background info will help. The west side (front) has 2 gables w/o ridge vents, only a couple of soffit vents on the sides and near the peak. The covered porch has no soffit vents (plan on installing continuous vent since we've had problems w/ ice dams) and is steep (about 12/12 I think).
The back side w/ the louvres is shallower (don't know exact pitch, maybe 3/12) and has some soffit vents (1 about every 5 or 6 ft).
How can I evaluate the ventilation to see if I need more or less exhaust or intake?
new roof, ridge vent was in est, but not installed... Zel1 Roofing/Siding 29 09-01-2010 04:30 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-21-2008 11:35 PM
Ventilating Roof with no ridge? NateHanson Roofing/Siding 7 12-30-2007 04:33 AM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 08:32 PM
