Ridge Vent With Two Different Ridge Heights? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-24-2012, 12:54 PM   #1
Special User
Rewards Points: 1,230
Ridge vent with two different ridge heights?
We're going to have to re-roof the house we just bought. I want to vent the attic properly (because we want a whole house fan), and from what I've read, a continuous ridge vent is the way to go.
However, this is a single-story ranch with two different ridge heights -- the taller over the house, and the shorter over the attached 2-car garage. I understand that the "chimney effect" is critical for attic venting, so I'm inclined to not ridge-vent the shorter garage ridge for fear it will spoil the soffit-to-ridge airflow on the rest of the house.
Other data -- the roof is hip (well, there are tiny "Dutch" gables, so it's mostly hip), but the attic spaces are interconnected with each other. I understand it's hard to get enough venting on a hip roof, so that makes this decision even more critical.
Thoughts?
tylernt is offline   Reply With Quote
Old 07-24-2012, 04:50 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
My thoughts are with a whole house fan you will need all the venting you can get on your hip roof, those fans put out a lot of air and I may be wrong but I don't think the ridge vents alone will be enough. If your whole house fan is pressurizing your attic space too much some of the air could find its way back in the house. I also have a hip ranch style home and am thinking about more vents with maybe even a small dormer on the back fitted with an attic type vent also.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-24-2012, 05:04 PM   #3
Special User
Agreed. Currently there are far too few soffit vents, so I will be adding enough vents that there is a bit more square footage in soffit vent as there is ridge venting. And of course I'll make sure that all of that will add up to equal or exceed the amount needed for the WHF.
Looking more closely at my roofline though, I think I changed my mind. I think the garage should be ridge vented, as there is a valley between the garage and the house. With no ridge vent, this would let a bubble of hot air stay trapped in the garage attic with nowhere to go... I guess that settles it then. Vent it.
Old 07-24-2012, 09:04 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
What type of ridge vent do you plan to use? The reason I asked is there are many who say to stay away from the Cobra Ridge Vent.
Jim
Old 07-24-2012, 11:29 PM   #5
Special User
Not sure what brand yet, but I know I want to avoid the squishy stuff. Rigid for me.
The Following User Says Thank You to tylernt For This Useful Post:
BigJim (07-25-2012)
Old 07-25-2012, 08:50 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
Big +1
While, when installed properly, it can work. I have seen enough instances of poorly installed versions that created big issues.
The Following User Says Thank You to Windows on Wash For This Useful Post:
BigJim (07-25-2012)
Ridge vent on 2:12 slope cathedral roof DaveM75 Roofing/Siding 5 09-28-2016 04:47 PM
Ridge vent shingling..How to do it properly? J S Machine Roofing/Siding 5 01-18-2011 12:58 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
Hip caps to ridge vent KEITHnhia Roofing/Siding 1 07-04-2009 02:17 PM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 04:22 PM
