Ridge Vent/Soffit Advice Needed - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-25-2009, 10:23 PM   #1
Next week I am starting to replace my roof of 20 years and I need some advice about ridge vent. The roof currently has roof vents (aluminum type) and no soffit vents. The end of the roof is just closed. The over hand where the soffits should be are about 8" maybe - so my question is should I add some soffit vents and go with a ridge vent to help reduce the heat build up? thanks
kw151002 is offline   Reply With Quote
Old 06-26-2009, 12:14 AM   #2
Install a continuous soffit strip vent in the overhang and also a continuous ridge vent, preferably the Shingle Vent II for better performance.
In the attic, make sure the insulation is not blocking the intake air flow from the overhangs, otherwise, you will have to install insuation baffle vent chutes to bypass the insulation and allow free flowing air fro the Intake to the Exhaust at the Ridge.
Ed
Ed the Roofer is offline   Reply With Quote
Ridge Vent/Soffit Advice Needed kw151002 Building & Construction 5 06-26-2009 02:26 PM
Advice needed. Complete Furnace & duct replacement - asbestos ductwrap (crawl space) vestaviascott HVAC 11 03-10-2009 06:40 PM
Forced air and radiant system advice needed jasoncave HVAC 1 01-06-2009 09:46 PM
Knee wall Ventilation advice needed N8E Roofing/Siding 9 06-29-2008 12:23 AM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing/Siding 6 02-20-2007 12:17 PM
