| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Examine Your Roof for Loose Shingles & Other Damage
by Expert Village
Hi! This is Jon on behalf of Expert Village. In this video clip, we will checking the roof for loose or missing shingles. To check for any loose or missing shingle, you just want to take a close look at your roof. If there are any areas that might look... Read More »
How to Frame the Roof Ridge
by Expert Village
Hi, I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. Where the ridge is to be ventilated and the coursing is less than a full tile, a one inch board is laid parallel with the ridge on each side... Read More »
How to Replace Vent Flashing
by eHow.com
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
How to Calculate Area for Shingles
by Expert Village
Hi, this is Jon on behalf of Expert Village. In this video clip we'll be calculating shingles. To calculate the number of bundles of shingles for a basic gable roof first we need to measure the length and the width of the rectangular areas that is adding... Read More »
How to Lay a Full Course of Metal Roofing
by Expert Village
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. Starting at the very first full course from the ridge, lay two panels simultaneously. The second course is used to accurately space the joints of the... Read More »
