Ridge Vent Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-12-2011, 12:54 PM   #1
Post
Ridge vent question
Hello from Beavercreek, Ohio.
Can anyone recommend a good ridge vent brand for easy installation/looks?
I have 92 feet to install on my roof.
Thanks, Splinters1
Splinters1 is offline   Reply With Quote
Old 09-12-2011, 09:16 PM   #2
Are you installing shingles, etc, or just trying to install a ridge vent? There are many issues you may need to address that will help the vent "work" as it should. I just want to make sure I respond with good information.
Indyarchyguy
Indyarchyguy is offline   Reply With Quote
The Following User Says Thank You to Indyarchyguy For This Useful Post:
Splinters1 (09-14-2011)
Old 09-13-2011, 10:23 PM   #3
ParagonEx's Avatar
Rewards Points: 150
I would suggest either ShingleVent II or GAF Snow Country. Both are very effective and designed to perform well.
ParagonEx is offline   Reply With Quote
The Following User Says Thank You to ParagonEx For This Useful Post:
Old 09-14-2011, 08:42 AM   #4
Rewards Points: 83
Look into Lomanco venting. They have a few different ridge vents available.
bcdemon is offline   Reply With Quote
The Following User Says Thank You to bcdemon For This Useful Post:
Old 09-14-2011, 06:06 PM   #5
Indyarchyguy
Thanks for the reply...I have proper soffit venting and have roof vents. The roof shingles are "curling" due to the heat. I would like to correct the ventilation by installing ridge vents and closing off the existing roof vents. I'm just installing ridge vents and shingling over them. Any suggestions would be appreciated
Splinters1
Ridge Vent with roof vents and Soffit vents apquery Roofing/Siding 10 08-08-2016 10:28 AM
Roof ventilaton - hip roof (ridge vent, fan, power vent ?) rkpatt Building & Construction 2 06-02-2011 05:21 PM
Ridge vent shingling..How to do it properly? J S Machine Roofing/Siding 5 01-18-2011 12:58 PM
proper intake vents for ridge vent?? arty007 Roofing/Siding 14 07-31-2010 01:28 PM
ridge vent ?'s Zel1 Roofing/Siding 6 05-19-2009 09:53 PM
