Ridge Vent And Power Vent? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-01-2010, 08:04 PM   #1
Ridge Vent and Power Vent?
I've read that different types of roof vents shouldn't be used in conjunction, as this may cause short-circuiting of air flow, but I haven't found a definitive answer. Should a Cobra ridge vent be installed if a power vent and a gable louver already exist? Or, must the power vent and gable louver be removed along with the roof louvers before a Cobra ridge vent is installed?
etern33 is offline   Reply With Quote
Old 10-06-2010, 12:54 AM   #2
Registered User
Rewards Points: 5,216
http://www.ronhungarter.com/ventilation_repairs.html
http://www.ronhungarter.com/black_mold.html
Gary
Old 10-07-2010, 06:41 PM   #3
Rewards Points: 1,088
Why do you think you need to add a ridge vent if you have a power vent and gable louvers already?
During the summer, the power vent will pull the heat out. Intake will come from your soffits, if you have them, and the gable louver. Heat will continue to exit via the power vent hole and the gable louver at nighttime when the fan will be off.
During the winter, the power vent will not turn on, so any heat will exit via your gable louvers, assuming you have soffits.
handy man88 is offline   Reply With Quote
Old 10-17-2010, 05:45 PM   #4
RoofDiagnostics's Avatar
In my option this is an issue that often results in people making absolute statements when they are dealing with unique situations.
The above referenced link showing a mold ridden attic because of faulty ventilation installation is an example of this. While that situation is most likely 100% accurate - it does not mean that all homes with multiple sources of roof ventilation will result in condensation issues.
See, if you were in a vacuum conducting a scientific experiment a roof possessing a power attic fan and a cobra ridge vent - would most likely result in a decreased efficiency of ventilation. BUT - that is a vacum - your home is not a science experiment.
From my experience, i think the result of an attic fan and ridge vent is "competition" for air flow in a specific area. So in the area around the fan, the air might be pulled from two sources...but the area 25 ft across from the attic fan, i believe the cobra ridge vent is effective. The overall result in most of the homes with multiple sources of ventilation is a well ventilated attic/roof.
Of course there will always be scenarios where i am wrong but i know there are many cases where multiple sources of ventilation do not result in the air "short circuiting"
My recommendation: Install the Cobra Vent, pay attention to the attic area... if you believe you are experiencing "short circuiting" - get rid of the power vent.
Hope it goes well!
RoofDiagnostics is offline   Reply With Quote
The Following User Says Thank You to RoofDiagnostics For This Useful Post:
seeyou (06-05-2011)
Old 10-18-2010, 04:35 PM   #5
I attempt to firstly use best practices and instructions per the ventilation manufacturers, along with the HVI, (Home Ventilation Institute), and seasoned with practical on hands experiences.
In your situation, I would advise following the manufacturers recommendations to NOT Short-Circuit the Exhaust Ventilation Flowage, so as to be in stricter accordance with their approved methods of installation practices.
But, at times I will allow for a considered alternative strategy that makes sense in a unique or particular situation if logic seems to follow with previous experiences.
Ed
Ed the Roofer is offline   Reply With Quote
Old 06-04-2011, 06:33 AM   #6
Rewards Points: 81
My house has a hip roof. The roofer installed a ridge vent (relatively short since it is a hip roof) and left the power vent but told me to disable it (disconnect the wiring). The attic is hotter now . So, if I reconnect the wiring and use the power vent also , it will short circuit the flow if I don't stop the flow through the ridge vent ? Any suggestions on how to accomplish disabling of the ridge vent (short of removing it entirely) ? -Thanks
rkpatt is offline   Reply With Quote
Old 06-04-2011, 12:58 PM   #7
Instead of disconnecting the wiring, you should have added an on/off switch and put it in the living space if possible, so that you can control the fan.
Given that, I would leave the fan on as "short circuiting the flow" is really overrated. If anything, the ridge vent will act like a soffit (intake) and add to the flow of the hot air out of the attic. Remember....warm air rises and as the temperature in the attic increases, so does the pressure.
If you insist on disabling the ridge vent, what you can do is use Tyvek tape and take the ridge slot from inside the attic to prevent air flow, but personally, I would not do it.
Old 06-06-2011, 08:06 AM   #8
Rewards Points: 81
I got the power vent operating again (connected through a switch). The attic temperature measured with my min/max hygrometer/thermometer located 3 ft from the top of insulation /4ft from the peak was lowered about 8 degrees with the fan on (132degF fan off -
124degF fan on =8 deg F difference . The max outside temperature was 95degF ) .
That temperature ( 125 deg F ) seems excessive and I am think that I need to increase the flow . I believe that I need to add more intake vents as well as bigger power ventilator . Do to access problems (2 and 3 stories), it will be be difficult to add more soffit vents. I would have to add some passive "turtle" vents on the non-street sides of the house a few feet up from the lower edge of the roof . Any recommendations on installing these (spacing, layout, straddle rafters, etc) are appreciated.
ref-
http://www.gaf.com/Roofing/Residenti...f-Louvers.aspx
- Thanks
Tags
cobra ridge vent , power vent
Ridge vent and power vent neikorott Roofing/Siding 1 09-09-2010 06:57 AM
Power Vent Question for Propane Boiler Moondaddie HVAC 4 12-23-2009 08:12 PM
Repair or replace gas heat unit and power vent PegTN HVAC 1 11-06-2009 07:40 PM
ridge vent vs. power ventillator retired guy 60 Roofing/Siding 6 07-16-2009 11:49 PM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 09:32 PM
