Ridge Vent And Power Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-08-2010, 04:31 PM   #1
Ridge vent and power vent
I'm having a new roof installed. I currently have two power vents on my roof. I'm having the two power vents replaced and was wondering if it's a good idea to have power vents and ridge vents installed together. I'm hearing different idea's. I feel that the power vents are working on a thermostat so they won't effect the ridge vent. Can someone give me some advise?
neikorott is offline   Reply With Quote
Old 09-09-2010, 06:57 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Do a search here. This topic has been discussed often, but the short answer is in most cases ridge vent and power vent mixing is a bad idea. The power vent can pull through the ridge vent rather the proper inlets leaving stagnant, moist air against the ceiling.
seeyou is offline   Reply With Quote
The Following User Says Thank You to seeyou For This Useful Post:
federer (09-09-2010)
Power Vent Question for Propane Boiler Moondaddie HVAC 4 12-23-2009 08:12 PM
Repair or replace gas heat unit and power vent PegTN HVAC 1 11-06-2009 07:40 PM
ridge vent vs. power ventillator retired guy 60 Roofing/Siding 6 07-16-2009 11:49 PM
Direct Vent Vs Power Vent APPY HVAC 1 02-15-2007 11:26 AM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 09:32 PM
