Ridge Vent Over Vaulted Ceilings? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-08-2011, 02:17 AM   #1
Ridge vent over vaulted ceilings?
Hello everyone! I'm builiding my first home and have tons of questions. The delima currently is ridgevents. My trusses span 40'. The middle of my home has a scissor trusses with 20' being vaulted. The house is 63' long. The vaulted part is 27'x20'. The garage attaches to the home, so it has an offset T shaped ridge. It also has a front and back porch, both 12'x12' under the same roof. Is a ridgevent suitable for this roof? If so, Do I install a ridgevent over the vaulted area? The roof is going to take S style concrete tiles. Is there a special ridgevent for that? Thank You.
EC1970 is offline   Reply With Quote
Old 01-08-2011, 06:35 AM   #2
Residential Roofer
Slyfox's Avatar
In comparison to asphalt/fiberglas shingles most everything you use for the tile installation is special, because it has a much higher profile.
Ridge vents are arguably the best exhaust ventilation to use,
everyone agrees it's the best exhaust system for over vaulted/cathedral ceiling area's.
If your using traditional insulation 'not foam' make sure you install baffles/air chutes not only at the eaves in those areas but all the way to the top of the ceiling where it opens up into the dead space/crawl space near the ridge.
Edited: Ask the folks at the supply house/store where your purchasing the tile for spec's on installation, this should include underlayments, flashing's, tile install, ventilation, etc.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
The Following User Says Thank You to Slyfox For This Useful Post:
EC1970 (01-08-2011)
new roof, ridge vent was in est, but not installed... Zel1 Roofing/Siding 29 09-01-2010 04:30 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Hip caps to ridge vent KEITHnhia Roofing/Siding 1 07-04-2009 01:17 PM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 03:22 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-21-2008 11:35 PM
