Ridge Vent Not Performing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-01-2010, 08:00 PM   #1
Rewards Points: 154
Ridge vent not performing
Last fall we had our roof replaced and after doing some research we decided to eliminate our attic fan and install ridge vents. The contractor made extra vent cut outs in the eves for better flow. I had to go in the attic the other day and the outside temp was around 79* and the attic was hotter than hell. I felt no air movement at all, even though outside their was a cool breeze, did we make the wrong choice? should we install an attic fan or????? They also took out all roof vents, and side gable vents when they did the ridge vent. Now I seem to think we were better off the way it was.............
turbomangt is offline   Reply With Quote
Old 05-01-2010, 08:36 PM   #2
kwikfishron's Avatar
Rewards Points: 420
Do you have eve vents?
kwikfishron is online now   Reply With Quote
Old 05-01-2010, 08:44 PM   #3
Make sure your insulation isnt stuffed down too far, interfering with the vent air coming from the eaves. If a gable was there originally whoever put the insulation in might have done it based on not having to worry about how close to the eave it gets. They make foam baffles you can install to keep the insulation away from the airspace
I just had a ridge vent added to most of my house (area over cathedral ceiling already had one)....roofer said it was definitely working, he could feel the heat. I still want to add those baffles myself though.
chrisexv6 is offline   Reply With Quote
Old 05-01-2010, 10:19 PM   #4
Registered User
Rewards Points: 5,498
"The contractor made extra vent cut outs in the eves for better flow." ----- make sure it is a balanced system: http://www.fureyco.com/content/image...ng_The_Air.pdf AND: http://www.airvent.com/homeowner/pro...it-specs.shtml
“I felt no air movement at all, even though outside their was a cool breeze, did we make the wrong choice?” ------- depends: http://files.buildsite.com/dbderived...rived20936.pdf
“should we install an attic fan or?????” ------ No: http://www.ronhungarter.com/black_mold.html
http://www.advancedenergy.org/buildi...%20Studies.pdf
“They also took out all roof vents, and side gable vents when they did the ridge vent.” ----------- Good: start reading on page 603: http://books.google.com/books?id=Z8a...0vents&f=false
Be safe, Gary
Old 05-01-2010, 10:35 PM   #5
Commercial Roofing
AaronB's Avatar
What does all of that mean in those links? Can;t ya just say it in here so we can read what you're saying?
You will not feel a breeze in most attics with ridge vents. They are vents, not fans. If you wanted a breeze, you coulda left the fan in place. The inportant part of venting is that you move enough air ti turn the attic air over every couple of hours.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 05-02-2010, 02:15 PM   #6
Registered User
1. make sure it is a balanced system:
2. depends--- on what type/brand of vent the article listed for the ratings.
3. No.
4. Good
These are the answers as I stated just before the links if you read it carefully again. The bold answer I added to explain the original.
Sorry if I confused anyone.
I try to show a reference proving my statements rather than just my opinion.
Be safe, Gary
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
jlhaslip (05-05-2010), tpolk (05-04-2010)
Old 05-02-2010, 02:59 PM   #7
Rewards Points: 154
Thanks to all for posting, well, for starters my ridge vent is a Cobra not sure if that matters, I read some of the links mentioned 90% of the material seems geared toward the professional. figures and numbers for air flow, should be left to the contractor, since we are paying them as part of this service. The other thing I gathered from these links is it not good to use multiple types of ventillation systems, so my idea of adding an attic fan does not sound like the right path according to the material here. I guess I would ask how do you measure the air flow for proper ventillation?I assume I would need a professional to do that, although someone I could trust becuase they will must likely want to sell me sometime..
Old 05-02-2010, 04:24 PM   #8
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Just because you don't feel a cool breeze doesn't mean your vent system is not working. Before with the attic fan, it's very possible the cool air you felt (if indeed you did feel a breeze in the attic) may have been conditioned air getting sucked from the living space. If you have the proper inlet and outlet with the soffit vents and ridge vent, then the system is working properly. On an 80 degree day, it's gonna be hot in the attic.
seeyou is offline   Reply With Quote
Old 05-02-2010, 07:52 PM   #9
MJW
What you feel really doesn't mean anything.
Heat goes to Cold, and wet goes to dry. This is how air moves. If that makes sense to you. Outside, (especially with the wind) what you are feeling is heat escaping from your body. Not that thge cool air is getting to you. Understand??
In your attic, the human body can't precisely feel temp and moisture changes from the outside temp or humidity.
Not saying you may not have a problem, just trying to explain that what you feel can't determine much.
As long as your shingles are not boiling and moisture levels are reasonable, you should be OK. The main reasons for venting is to keep shingles from over heating and to get rid of moisture that is created inside the home that makes it's way into the attic. The newer homes keep more moisture in the home, using poly mainly, but also various insulation types, tape, caulk, etc.. Then there are other problems......but now I'm just rambling with info that has nothing to do with your problem...
Check the actual temps and humidity levels to determine if it should be a concern.
MJW is offline   Reply With Quote
Old 05-02-2010, 08:37 PM   #10
Rewards Points: 1,088
So what is the recommendation for homes with peak roofs (results in shorter ridge vents)?
I guess that means closing the ridge vents and adding powered attic fan(s)?
handy man88 is offline   Reply With Quote
Old 05-03-2010, 07:15 AM   #11
Rewards Points: 1,500
The material used to line the ridge vent could have been squished too much barely letting hot air seep out as opposed to flow out.
Old 05-04-2010, 06:25 PM   #12
Simple calculations.
The total square footage of the entire attic floor space divided by 150 will provide you the total amount of square FEET of ventilation you need.
Ventilation products are sold in Square Inch Ratings, so multiply that square foot number by 144 to arrive at the amount of necessary square inches required.
Also, balanced is a sought after Intake to Exhaust Ratio, but increasing the Intake to any higher amount will not adversely affect the air flowage. Actually, the more Intake, the better the total ventilation system is.
Ed
Ed the Roofer is offline   Reply With Quote
Old 05-04-2010, 06:38 PM   #13
so i have a 160 sq/ft addition, i need 1 sq/ft soffit vent?
The older I get the better I was
Old 05-05-2010, 12:21 PM   #14
Yes, pretty close to that. The amount can be decreased in half if you have an equal, aka balanced amount of Exhaust Ventilation and if there is a continuous vapor barrier on the under side of the insulation separating the heated interior ceiling from the attic area.
Ed
new roof, ridge vent was in est, but not installed... Zel1 Roofing/Siding 29 09-01-2010 04:30 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Hip caps to ridge vent KEITHnhia Roofing/Siding 1 07-04-2009 01:17 PM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 03:22 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-21-2008 11:35 PM
