Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-04-2012, 09:12 AM   #1
Ridge vent not adequate
I am leaving a 3" space umder the roof in each rafter cavity, but the ridge vent only provides 1.5" at the top. Is this adequate?
check is offline   Reply With Quote
Old 08-04-2012, 10:33 AM   #2
Exterior Construction
Windows on Wash's Avatar
Always better to err on the side of more intake than exhaust. Most soffits and vents don't flow what you think and you need to look up the net free area of the vents in question but you are probably just fine.
Old 08-04-2012, 12:49 PM   #3
Agreed with WoW, there are directions on the ridge vents that tell you how much to cut. It is a little different based on whether or not you have a ridge beam or trusses.
A house I am working on this past week the carpenter but the ridge vent 2 inches on either side of the ridge. Now the ridge don't look like a ridge, looks like a min-flat section up there. Cutting too much can also affect the weather-tightness.
roofnron is offline   Reply With Quote
Old 08-11-2012, 07:53 PM   #4
I am using a ridge beam (offset a bit), so I get 1.5" on either side of the ridge board, but 3" at the bottom of each rafter cavity, continuous up to very near the top. I just don't see how 3" of space (on each side) can vent out completely through a 1.5" (per side) ridge vent. Still, the Ontario Building Code requires a minimum 2.5", and I am creating the 3" space in each rafter cavity, then furring the 2 X 6 rafters out 3" (with n=2 2 X 2's) so I still have 5.5" left to fill with R22 Roxul. (The I will apply 4' x 8' sheets of R13 foil-covered Thermax high-density foam overtop, for a total R value of R35.)
Is it common for roofers to NOT slice underlayment on a ridge vent before installing? jcarlan Roofing 29 01-05-2012 04:26 PM
snow country ridge vent on 2:12 pitch roof fxtm Roofing 4 11-01-2011 07:26 PM
Roof ventilaton - hip roof (ridge vent, fan, power vent ?) rkpatt Building & Construction 2 06-02-2011 05:21 PM
Ridge vent shingling..How to do it properly? J S Machine Roofing 5 01-18-2011 12:58 PM
Ridge vent on 2:12 slope cathedral roof DaveM75 Roofing 4 08-19-2010 12:06 PM
