Is Ridge Vent Needed On Non-attic/vaulted Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-06-2013, 04:50 PM   #1
Rewards Points: 12
Is ridge vent needed on non-attic/vaulted roof?
Hello All,
I've seen the threads regarding ridge venting on homes with attic and/or truss spaces that should be ventilated. My home, however, is all vaulted ceilings consisting of 12' deep rafters with drywall on the inside, batt insulation directly behind that, and then an air gap between the top of the insulation and the underside of the roof sheathing. When new, we installed both eave vents and ridge venting, but the ridge benting we installed has been problematic and I am wondering if it's really necessary or beneficial for this type of roof. Any advice or guidence would be much appreciated. Cheers!
scottmcll is offline   Reply With Quote
Old 07-06-2013, 10:07 PM   #2
Rewards Points: 12,820
Soffit and ridge venting is needed.
What style venting was giving you trouble?
Was it roll venting? That stuff is useless and does not allow enough venting.
Windows on Wash (07-07-2013)
Old 07-10-2013, 06:35 PM   #3
Rewards Points: 12
Thanks for responding. It is the plastic type that had a feeble thin strip of foam on the edges. Occasionally water gets in when its windy while raining. The reason I asked was because I onlt saw reference to it being needed in homes with attics. If that were the case, I'd just remove it, fill in the gap in the sheathing and shingle over it. Otherwise, I will replace it with a metal ridge vent. So you're sure it's needed for a vaulted roof as I described in my original post?
Old 07-11-2013, 10:35 AM   #4
Rewards Points: 268
If you don't have the ridge vent, condensation will form and create mold that, over time will become visible on the in side of the drywall
packer_rich is offline   Reply With Quote
The Following User Says Thank You to packer_rich For This Useful Post:
scottmcll (07-11-2013)
ridge vent, gable, moisture in the attic racebum Roofing/Siding 40 03-27-2012 02:26 PM
Install ridge vent in only a portion of roof? Holdfast Roofing/Siding 0 07-29-2011 03:01 PM
Are exposed nails on a roof ridge vent acceptable? Bmcox Roofing/Siding 2 12-04-2010 06:59 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
Ridge vent Plus roof fan? mano Roofing/Siding 6 06-30-2009 03:59 PM
