Ridge Vent On Low Slope Torchdown 2/12 - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-25-2010, 12:47 PM   #1
ridge vent on low slope torchdown 2/12
Hi all,
I'm a long time diyer and have an issue with the house my wife and I bought a few months ago.
The roof is a torch down with a 2/12 pitch. it has venting all along the eaves, but very limited venting near the ridge.
We have a cathedral ceiling that drips on occasion, I'm assuming due to condensation issues.
I'd like to have a ridge vent installed to improve airflow, since the air gets trapped at the ridge and there is no flow between the rafters.
We also have a large chimney and I'd like to put a venting system below but near the chimney to allow the hot air to escape.
Any ideas you have would be appreciated.
We are also thinking of coating the roof this summer, but would like to find some coating that isn't bright silver or white.
Thanks for you ideas.
photo can be found here http://picasaweb.google.com/Alex.Tat...68319868624146
alexinseattle is offline   Reply With Quote
Old 06-25-2010, 01:59 PM   #2
I would first install a double stacked layer of 2" x 4"s on each side of the newly cut ridge vent slot and prior to installation, I would cut the wood into a canilever at a 45* angle and then apply a fresh sheet of new modified bitumen over the wood surface and properly terminate it to the inside edge of the top of the wood and then install the ridge vent on top of this structure to minimize or even hopefully eliminate the potential for moisture intrusion due to the minimal slope of the roof surface.
Ed
Ed the Roofer is offline   Reply With Quote
Old 06-26-2010, 10:05 PM   #3
Doing This Way Too Long
Rewards Points: 532
Acrylics and elastomerics can be tinted at your local paint store.
OldNBroken is offline   Reply With Quote
Old 06-26-2015, 08:12 PM   #4
Rewards Points: 6
I know this is an old thread, but I'm in the same situation as Alex and wanted to see how it worked out for him. Ed, would it be possible for you to draw up a picture of what you are proposing and post it here? I think I understand what you are suggesting, but I want to make sure before going at it.
chrisinseattle is offline   Reply With Quote
Old 06-27-2015, 07:11 AM   #5
Low Slope Roofing
Rewards Points: 114
I believe this is what ed was trying to describe.
1985gt is offline   Reply With Quote
The Following User Says Thank You to 1985gt For This Useful Post:
Windows on Wash (06-27-2015)
new roof, ridge vent was in est, but not installed... Zel1 Roofing/Siding 29 09-01-2010 04:30 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Hip caps to ridge vent KEITHnhia Roofing/Siding 1 07-04-2009 01:17 PM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 03:22 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-21-2008 11:35 PM
