Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 05-08-2006, 07:14 PM   #1
Ridge Vent - Low-pitched roof?
I need some advise on how to proceed with a ventilation problem. I have a low-pitched roof, about 1.5":12". I have a catherdal ceiling and I appear to had excessive heat build up in the rafters. My interior plaster on the ceiling is peeling as well as the paint and when I touch the ceiling on hot days it's really hot (in So.Cal). There seems to be plenty of vents around the eaves it's just that there's no vents near the peak of the roof. I've installed a power vent in the part of the house that doesn't have the catherdal ceilings but it must not be sufficent for the catherdral area.
Anyway, it seems like a good solution would be a ridge vent. But, since the roof pitch is quite low I'm worried about wind-driven rain, etc, getting into the ridge vent. Also, doing some research on the web I haven;t found a ridge vent that works below 2:12 pitch.
Is there a ridge vent solution for me or should I look into some other approach?
Thanks a bunch
Brian
BTW, my roof is currently a touch-down rolled bitumen roof.
brianp is offline   Reply With Quote
Old 05-08-2006, 07:57 PM   #2
Commercial Roofing
AaronB's Avatar
I have seen framed vents installed on low slopers in the same situation, but a lot of it also depends on your insulation configuration...you need a gap between the insulation and the roof deck. Do you have any rooftop insulation?
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 05-08-2006, 09:32 PM   #3
Aaron
Yes, there is R-19 in the roof w/ 6" rafters. So, not much of a gap, but a gap.
Brian
Ridge Vent: width of cut judym Roofing/Siding 12 09-09-2012 03:20 AM
Useless Ridge Vent? itwerx2 Roofing/Siding 22 10-22-2007 10:57 PM
Losing aggregate from asphalt shingle ridge bkspero Roofing/Siding 8 07-19-2007 10:40 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
Ridge vent installation cost Douche Roofing/Siding 1 07-26-2006 05:59 AM
