Ridge Vent Leak - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-12-2011, 10:13 AM   #1
Unhappy
Ridge Vent leak
We recently moved in our new place. The roof is asphalt shingle and is 14 years old. During heavy rains and wind last week, we saw water trickling down the ridge vent in the attic. We received a quote from a contractor to cap the ridge vent and instal 5 new square vents. Would capping the vents and installing the square vents solve our problem and also ventilate the roof enough? It also snows in winter here. Any recommendations would be appreciated.
newowner3 is offline   Reply With Quote
Old 12-12-2011, 10:56 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I wonder why ridge vents are leaking. But yes. It can be re-ridged and go with the others. There is a formula for amout of vents you need according to cubic feet of attic space. Make sure your roofer follows this spec.
titanoman is offline   Reply With Quote
Old 12-12-2011, 04:18 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,092
Why not replace the ridge vent with one of the more screening and weatherproof options?
The Following User Says Thank You to Windows on Wash For This Useful Post:
tcleve4911 (12-12-2011)
Old 12-12-2011, 04:34 PM   #4
Rewards Points: 13,450
If it's three tab shingles then 14 years is about all your going to get out of them, there would be no since just doing a fix when your due for a new roof. If one if the caps is cracked where the two pieces come together it's going to leak.
Windows on Wash (12-12-2011)
Old 12-12-2011, 05:31 PM   #5
+1
Even if it is one of those "30-year" roofs...you are nearing its projected lifespan as well.
Old 12-12-2011, 06:15 PM   #6
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Originally Posted by Windows on Wash View Post
+1
30 is the new 'lifetime".....
seeyou is offline   Reply With Quote
Old 12-12-2011, 06:18 PM   #7
Disabled wood vet
titanoman's Avatar
These guys probably know their roof is old. Some new ridge caps or vents will probably buy them a few more years if they can't afford a new roof right now.
Old 12-12-2011, 06:19 PM   #8
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
I'd wager that you have an improperly installed ridge vent. Slot cut too wide, torn ridge caps, improper nailing, etc. I prefer ridge vent over box vents in most instances. It would be wise to figure out what the problem really is before solving it.
The Following User Says Thank You to seeyou For This Useful Post:
MJW (12-12-2011)
Old 12-12-2011, 06:21 PM   #9
Old 12-12-2011, 09:36 PM   #10
There are a couple of things you can do:
1. Remove the existing ridge vent and install a newer version. The older style type might be letting wind-driven rain in in a way a newer one (with side baffles) wouldn't.
2. The way you can determine sufficient ventilation in pulling off the old ridge vent, capping, and going with new pod vents goes like this: a standard pod vent will allow 50 square inches of exhaust ventilation. Essentially, you want 1 square inch of exhaust ventilation (plus one square inch of intake ventilation at the soffits) for every TWO SQUARE FEET of attic floor space. If your contractor is any good at what they're doing, they ought to be able to show you the calculation for ventilation.
3. Try the COBRA Snow Country Ridge vent from GAF if you get snow.
Aaron
www.american-roofing.biz
Double-A is offline   Reply With Quote
Old 12-13-2011, 06:19 AM   #11
Thanks everyone! We have decided to go with a new ridge vents. The roofer will be coming in today. Will test them when it rains on Thursday.
Ridge Vent with roof vents and Soffit vents apquery Roofing/Siding 10 08-08-2016 09:28 AM
snow country ridge vent on 2:12 pitch roof fxtm Roofing/Siding 4 11-01-2011 06:26 PM
Hip caps to ridge vent KEITHnhia Roofing/Siding 1 07-04-2009 01:17 PM
Ridge Vent Leaking 35thLE Roofing/Siding 5 01-08-2009 11:33 AM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 03:22 PM
