Ridge Vent Issue - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-29-2010, 07:00 AM   #1
ridge vent issue
roofer installed typar over the ridgevent and then installed cobra vent and filter. we are up in the adirondacks (cold weather) and building a new log home. the house is retaining moisture and the insullator says it is because he put the typar barrier up and the house is not breathing properly. should be slice the typar open, which was pput there to further protect against bug intrusion?
wrene is offline   Reply With Quote
Old 11-29-2010, 10:01 AM   #2
jlhaslip's Avatar
Rewards Points: 2,188
I would use screen over the vent instead of Typar.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 12-18-2010, 05:24 PM   #3
Ridge Vent Issue
I have the Omni Ridge Vent on my home. The plastic one that comes in the 4 foot sections. I live in Minnesota and we get lots of snow here. When we get a strong wind, snow will come into your attic. Lots of it too. The fine snow will come in through the slots in this product and sit in the attic. It eventually will melt and ruin insulation, sheetrock and whatever else lies beneath. I would suggest using a different product if it's not to late.
azl6dpx is offline   Reply With Quote
Old 12-18-2010, 05:25 PM   #4
Ridge Vent Issues with Snow
Old 12-19-2010, 06:33 AM   #5
Residential Roofer
Slyfox's Avatar
If your roofer installed typar over the slot in the deck and than installed the ridge vent, the ridge vent is not working 'breathing' and you simply need to cut that typar out, if you have a large enough attic/crawl space over your ceiling area you can cut it out from inside with out removing the ridge vent.
(Being extremely careful to not cut the vent)
You do not need bug protection under the ridge vent, only need that at the ends and they make end caps.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Ridge vent on 2:12 slope cathedral roof DaveM75 Roofing/Siding 5 09-28-2016 03:47 PM
proper intake vents for ridge vent?? arty007 Roofing/Siding 14 07-31-2010 12:28 PM
ridge vent w/ roof louvres? byocum Roofing/Siding 3 08-31-2009 06:17 PM
Ridge vent leaking? Or what? Whatever1 Roofing/Siding 10 09-25-2008 06:24 PM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 09:47 AM
