Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 02-03-2011, 08:05 AM   #1
Ridge vent on house with no attic
We need new roof on our Georgia mountain house. There is no attic but cathedral ceiling in 2nd floor bedrooms. Will ridge vent allow critter to enter house. In winter, will heat escape?
edrobie is offline   Reply With Quote
Old 02-03-2011, 08:13 AM   #2
waterman1971's Avatar
Is it insulated between the rafters? If so, is rafter venting in place?
waterman1971 is offline   Reply With Quote
Old 02-03-2011, 08:26 AM   #3
A single unit roof/rafters/insulation/ceiling will not benefit from ridge vents.
A "suspended ceiling" arrangement with the ceiling, then the insulation, then an empty space and then the roofing can use a ridge vent provided that the empty space goes all the way down to the eaves where there are soffit vents. This is rare unless you have a real suspended ceiling because a space of less than 18 inches between ceiling and roof will likely be completely filled with insulation.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
new roof, ridge vent was in est, but not installed... Zel1 Roofing/Siding 29 09-01-2010 05:30 PM
Adding attic vent w/existing ridge vent GeorgiaGeek Roofing/Siding 6 05-05-2009 03:04 AM
HOT attic, ridge vent/soffit vent questions gone_fishing Roofing/Siding 36 07-14-2008 10:26 PM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 04:22 PM
is an attic vent required for cedar shingle roof? walenta Building & Construction 2 10-25-2007 11:31 AM
