Ridge Vent And Flashing Around Chimney - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-27-2010, 12:11 PM   #1
ridge vent and flashing around chimney
Please help I am a female and do not know much about this stuff I had my roof done about 2years age I was up on roof and notice on the roof ridge vent that holes are appearing on the shingles its like popping up as if a nail was under it. also he did not put flashing around my chimney and I notice the wood is starting to rod where it meet roof, is this rot caused from not having a flashing there? thanks for your help
cupcake8 is offline   Reply With Quote
Old 09-27-2010, 12:27 PM   #2
Chicago, IL
Michael Thomas's Avatar
Sounds like there may indeed be problems with the roof, but it's not possible to make intelligent comments without seeing pictures of your problem(s).
To upload pictures:
How to Upload Photos - A short Guide
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 09-27-2010, 01:14 PM   #3
here are the pic,
ridge vent and flashing around chimney-lori-006.jpg   ridge vent and flashing around chimney-lori-004.jpg   ridge vent and flashing around chimney-lori-001.jpg   ridge vent and flashing around chimney-lori-003.jpg
Old 09-27-2010, 01:22 PM   #4
here are the pic,[ATTACH]25158[/ATridge vent and flashing around chimney-lori-003.jpgridge vent and flashing around chimney-lori-004.jpgridge vent and flashing around chimney-lori-006.jpgTACH]ridge vent and flashing around chimney-lori-002.jpg
Old 09-27-2010, 05:40 PM   #5
Chicago, IL
1) It's possible that there was existing flashing under the chimney chase (the "box" around the chimney flue) and the new roof was applied over it, or that the there is a vent or flue inside the chase which is separately flashed to the roof - neither is a correct method of flashing that chase, but either would be less likely to leak than no flashing at all.
Irrespective, that attempt to "flash" with roofing cement is incorrect, and the chase needs to be inspected by a competent roofer and the junction corrected as required. Correction of missing or damaged chase flashings often requires removing and replacing some of the adjacent shingles and/or the lower portion of the chase itself:
Ideally, the roofer will "hold back" the repaired chase an inch or two above the roof surface to slow water damage to the chase material and allow inspection and maintenance of the flashings.
2) It's hard to tell exactly what's happening in the pictures at the ridge as the foreground is out of focus, but it indeed looks like some nails were under-driven and/or are backing out, and also that someone may have steeped onto the ridge vents in these areas.
Depending on the shingle condition it may be possible to re-fasten the shingles and seal the nail openings, or it may be necessary to replace some or all of the ridge shingles.
3) In my experience when you see these sorts of problems, others will often be discovered when a competent roofer inspects the entire roof.
4) Even a roof of that pitch can be hazardous for someone not used to walking roofs - be careful up there!
flashing, vents Alto Roofing/Siding 1 06-18-2010 03:25 PM
Vent Flashing 3rdroofdown Roofing/Siding 2 11-13-2009 09:16 PM
Need roofing tips! dc4nomore Roofing/Siding 114 07-03-2009 08:01 AM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Plumbing vent flashing FatAugie Roofing/Siding 7 08-24-2007 09:30 PM
